Fitting Vac Take Offs To A Maniflow Weber Manifold
#16
Posted 28 April 2010 - 10:31 AM
#17
Posted 28 April 2010 - 10:48 AM
unless you have the same question as to which size adaptors to fit........ and from your link i would guess 6mm would be correct - well that is what i'd be using!
Edited by Wilson1330, 28 April 2010 - 10:49 AM.
#19
Posted 28 April 2010 - 01:19 PM
#20
Posted 28 April 2010 - 01:35 PM
you can also stretch smaller pipe over bigger tails
#21
Posted 28 April 2010 - 04:11 PM
The pipe and fittings I use are 6mm O/D general purpose pneumatic hose from HERE, Its a perfect fit on the MJ MAP sensor and gives a totally sealed install - saves headaches finding vacuum leaks later.
That bloke gives a good service too
#22
Posted 28 April 2010 - 04:25 PM
#23
Posted 28 April 2010 - 04:39 PM
can just about see if here
then i used a parrelel Y connecter to split it, then at the manifold it was tapped, used tapered push fit connecters, can *just* about see them in the picture perhaps
#24
Posted 28 April 2010 - 06:54 PM
Sorry David, only just seen this. The bosses I made from 6mm plate, tapped and then ground down to 1/8 NTPF I think it was. The box is now done away with, it leaked and looked crap. All I use now is a few coils of the pipe layed under the carpet (when its in), this helps keep the vacuum fairly stable.
That bloke gives a good service too.
Arse!!
Just bought some brass items to fit the the manifold! So that guy sells unions hat can be tapped into the manifold and then push fit tubing to.
Hmm may end up buying those anyway.
My plan currently is to have the manifold drilled and tapped, but to also have them silver soldered to the manifold - to try and keep it old skool looking....
#25
Posted 30 April 2010 - 12:01 AM
#26
Posted 30 April 2010 - 07:45 AM
