Breather Filters
22 replies to this topic
#1 RayBoogs
RayBoogs
  • 1,109 posts
Posted 15 April 2010 - 05:38 PM
Model:Rover Cooper (SPi)
Year:1995
Hi everyone,
i was just wondering how to fit crankcase breather filters i was just wondering if the pipe leading from the pipe into the manifold needs to be kept or you just disconnect the pipe and put the filter on the end.
any help appreciated
Jack
#2 il-barba
il-barba
  • 839 posts
  • Local Club: malta mini
Posted 15 April 2010 - 06:56 PM
the pipe at the manifold end needs to be closed off.
note that this mod is not really good for road cars, because it will make the oil dirty and harm your engine whilst dirtying your engine bay
#3 Pauly
Pauly
  • 4,213 posts
Posted 15 April 2010 - 07:50 PM
Your best keeping the original system, filters are not very good at all for an engine, you need to create a vaccum in the crankcase to take away the vapours and pressure in the crankcase, without it the vapour and pressure will just build up.
#4 RayBoogs
RayBoogs
  • 1,109 posts
Posted 16 April 2010 - 09:57 AM
oh right ok, i was just wondering about it as ive seen a few roads cars with it and wondered if there was any benefit but obviously not haha
Jack
#5 Ro4chy
Ro4chy
  • 98 posts
  • Local Club: Not yet but looking
Posted 16 April 2010 - 10:40 AM
Sorry to hi-jack this but I have one of these breathers on my car and often get an oily smell in the car + dirty engine bay. What would I need to do to get remove the breather and put it back as it should be?
I have a 91 Carb Cooper.
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 16 April 2010 - 12:35 PM
Check this out (you'll be wanting HIF type carburettors 1990-1994): -
Click Me
Price List
#7 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 16 April 2010 - 01:02 PM
Same here, except I have a weber carb with no where to "aim" the oily fumes :P
#8 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 16 April 2010 - 06:48 PM
Could i simply fit a take off pipe into the rocker cover and let them vent into there - or does it need to be connected to the inlet to create the vacuum?
Im concerned doing this as i will be fitting Megajolt with MAP sensor and don't want it getting all gunged up!
#9 Hughes
Hughes
  • 377 posts
Posted 16 April 2010 - 06:49 PM
I have my breather pipes running into a length of hose that runs under the car and away. No oily smells but it doesn't create a vacuum obviously.
Although interestingly there an article by Keith Calver on the Mini Spares website that appears to suggest it isnt an issue although they seem to have disappeared at the mo.
#10 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 April 2010 - 07:03 PM
whats wrong with piping them into the air filter
#11 Pauly
Pauly
  • 4,213 posts
Posted 16 April 2010 - 07:04 PM
The carb sucks the fumes out the breathers, you could fit a catch tank?
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 April 2010 - 08:29 PM
If you don't have suction on the crankcase - you WILL have oil leaks and eventually a slipping clutch. Piping in the air cleaner will just plaster it with messy oil! I can only suggest a small hole is drilled in the weber inlet manifold *(I used 1/8" diameter) and the breather hose connected to that. These breather filters are a big waste of money!
I actually drilled and tapped the manifold for a servo take off - then filled the take-off with plastic metal, and then drilled a 1/8" hole through the filling.
#13 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 16 April 2010 - 08:30 PM
How would that work? As I have no vacuum at all from the inlet track? Or would the catch tack be inbetween the breathers and the manifold?
I need to have 2 vac pipes fitted into the carb and im considering having 4 fitted (2 on each branch) for the vac advance and the others for the breathers?
Opinions?
#14 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 16 April 2010 - 08:42 PM
Click Me
Price List
so where the info for 1275cc engines 1981-1989 ?
Edited by minidan, 16 April 2010 - 08:45 PM.
#15 samsfern
samsfern
  • 5,243 posts
Posted 16 April 2010 - 08:48 PM
mine are filtered, carbs are blanked off, doesnt give me any problems with leaks, etc....
