Breather Filters
#16
Posted 16 April 2010 - 08:50 PM
#17
Posted 16 April 2010 - 08:56 PM
Edited by samsernie, 16 April 2010 - 09:03 PM.
#18
Posted 16 April 2010 - 09:26 PM
Same here, except I have a weber carb with no where to "aim" the oily fumes
whats wrong with piping them into the air filter
I physically can't - i have soak filters over the trumpets!
#19
Posted 16 April 2010 - 09:29 PM
If you don't have suction on the crankcase - you WILL have oil leaks and eventually a slipping clutch. Piping in the air cleaner will just plaster it with messy oil! I can only suggest a small hole is drilled in the weber inlet manifold *(I used 1/8" diameter) and the breather hose connected to that. These breather filters are a big waste of money!
I actually drilled and tapped the manifold for a servo take off - then filled the take-off with plastic metal, and then drilled a 1/8" hole through the filling.
*touches wood* as of yet I have no oil leaks as such - but it has only done about 1000 miles in a year!
So it looks like i will need 2 pairs of vac pipes put in the manifold as I don't want it to breathe through only one branch of the carb.
Any suggestions what to use to fit vac pipes into a steel manifold - could i simply have som lengths of copper brakeline silver soldered into it?
#20
Posted 16 April 2010 - 09:34 PM
Edited by samsernie, 16 April 2010 - 09:36 PM.
#21
Posted 16 April 2010 - 09:43 PM
Edited by customcart, 16 April 2010 - 09:44 PM.
#22
Posted 16 April 2010 - 09:48 PM
#23
Posted 16 April 2010 - 09:58 PM
how do you plumb the breathers into the carb and also, why is it not already like this on our engines? ie : why are we arguing about how or why it should be done.
