Loud Buzzing Noise From Boot Area / Petrol Tank
#16
Posted 19 April 2010 - 09:06 PM
#17
Is the buzzing constant? And is it particularly loud? In my SPi if I'm stationary and the radio off, I can hear a faint whine from the fuel pump but not very prominent. It does sound loud when you first turn on the ignition. If it is an onimous, continuous buzz when you are driving along then I don't know the answer for definite - only that it does sound like the fuel pump is making the noise.
Well as soon as you turn the key and get it to the point where by one more turn will start the engine(eg the oil light and battery light/s are on) the fuel pump does make the exact noise(loud buzz) but stops after approx 2 seconds(kinda like the fuel pump initializing)...but when the the engine is actually started the buzz is just constant!
ps - i've checked and there no bee's present!![]()
That's exactly what mine does so I think you are fine.
If I turn the ignition on I can hear it go BUZZZZZZZZZZZZZZZZZZZZZZ! then it stops after about 2 seconds or so, then when I start the engine it starts buzzing again. Apparently all it is, is the pump priming or something. So don't worry, it's normal
I can hear the buzz when I am at traffic lights, when it's just on tick over. But when I am going a long I hardly notice it at all. Oh and when I open the boot I can hear it obviouslly!
#18
Posted 19 April 2010 - 09:07 PM
#19
Posted 19 April 2010 - 09:10 PM
Holy guacamole!! well i wasn't expecting that price for a fuel pump on a mini....i've been singing the mini's praises on the cost of parts since i bought the little devil on yesterday!
Found this which is slightly better value....then theres always a 2nd hand part on ebay for £60! http://www.minisport..._WFX100810.html
#20
Posted 19 April 2010 - 09:21 PM
#21
Posted 19 April 2010 - 09:34 PM
You will notice it with the boot open of course. You shouldn't be able to hear it on the move, but on tickover you should be able to hear a faint, high pitched buzz.
That's alrite then. I can hear it on tick over only if I try really hard to hear it!
it's not an mot fail is it if it's too loud? That's what i've been told ...
#22
Posted 19 April 2010 - 09:40 PM
Before I splash the cash i may just remove the little bugger from the tank to see if i can see any obvious blocks/issues with the pump...
by the way - Does anyone know if a 1995 Sprite has the MPI or SPI fuel injection system??
Thanks!
#23
Posted 19 April 2010 - 09:45 PM
Thanks!
Spi
#24
Posted 19 April 2010 - 09:46 PM
I would be very surprised if your car failed on a noise that didnt reflect a safety issue...eg a buzzing noise...i mean, what the worst that could happen if your fuel pump failed...you'd slow down right!
#25
Posted 19 April 2010 - 09:47 PM
Thanks!
SpiMine is 95 and that's spi. I think mpi was 96 onwards....
cheers alex...
#26
Posted 19 April 2010 - 09:49 PM
Thanks!
cheers alex...
It's ok
What colour is your Mini by the way!?
#27
Posted 19 April 2010 - 10:11 PM
[/quote]
well it red for now....but i'm thinking i'll be having it resprayed in yellow(like bumble bee from transformers)...with a black roof and black leather interior!
ps - do you know if both the spi and mpi fuel pumps are located inside the petrol tank?
#28
Posted 19 April 2010 - 10:18 PM
Yeah I am sure it is located inside the fuel tank... but not 100% sure. Have a look tomorrow, I am sure you will be able to see it!
Your plans for your mini sound great! :thumbsup
#29
Posted 07 October 2022 - 11:27 AM
Deffo sounds like it was inside the tank but moving the fuel lines about and releasing them a little from the strap that holds the tank in place and now it’s gone.
I know this is an old post but if it helps someone then great 😊
