Wing Welding Help
21 replies to this topic
#16 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 21 May 2010 - 07:26 PM
Just for info!!
Using Body filler in the seams is a VERY VERY VERY bad idea!!
No matter how much you weld them, the wing to front panel seam/wing to scuttle seam, will always move. If you fill the gaps with filler then it will crack as the body filler isn't flexible.
To fill the gaps use flexible seam sealer(not silcon sealent!!).
I would assume an acrylic seam sealer would suffice?
#17 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 21 May 2010 - 08:45 PM
Not sure to be honest, I don't know if the paint would react to it?
I'd play safe and use the proper automotive stuff, its not that expensive.
#18 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 21 May 2010 - 08:46 PM
Ignorant question from someone in the Colony across the Pond:
I keep seeing reference to using a linisher or a linishing wheel. I have never heard the word before (I guess we don't speak proper English over here). What is it- a sander, grinder or what? Thanks.
Linishing is using a sanding pad on an angle grinder, like a flap wheel.
#19 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 21 May 2010 - 08:56 PM
its pieces of sandpaper overlapped and its in a disc shape and fits onto a angle grinder :)
Danny.
#20 1964Woody
1964Woody
  • 201 posts
Posted 21 May 2010 - 09:19 PM
Thanks. We call them Flap Discs.
#21 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 22 May 2010 - 07:28 AM
you can generally paint over acrilyc sealants, but I'm not sure of its suitability for automotive paints. I'll get some proper auto stuff instead.
#22 Rich.
Rich.
  • 520 posts
Posted 22 May 2010 - 09:45 AM
As does almost everyone else, just people trying to sound posh :(
Rich
