have you signed up as a member ?
Metro Subby
The Freeb
, Apr 21 2010 04:50 PM
19 replies to this topic
#16
Posted 22 April 2010 - 05:33 PM
#17
Posted 22 April 2010 - 07:30 PM
i think so. is the more then one way to sign up?
#18
Posted 28 April 2010 - 08:39 AM
Having done 3 conversions myself & gone through the DVLA inspection, I can tell you that they are more concerned with the chassis remaining untouched. If it unbolts you can take it off, cutting into the chassis means an automatic IVA & a Q plate. The Mini has a monocoque chassis, so in theory if you fit a sunroof you have cut the chassis & it needs an IVA. I have argued big time with the DVLA over one of my conversions & the end result came back that I cut the roof which means I cut the chassis = IVA & Q plate. I argued with them about the points system & I believed that my car qualified under this system. They just came back with "you cut the chassis so you will have to go through the IVA & have a Q plate". So this begs the question on what you can & cant do, fibreglass wings, boot floor, inner wings, one piece bolt on front end? I think most heavily modified Minis would not pass a DVLA inspection if the inspector was in the wrong mood, the rules are down to interpretation.
Regards
Jerry
Regards
Jerry
Edited by hayling mini, 28 April 2010 - 08:42 AM.
#19
Posted 30 April 2010 - 04:31 PM
thanks jerry
have you done a vvc conversion?
any advice on the best way to go for the subframe?
#20
Posted 30 April 2010 - 07:02 PM
thanks jerry
I have done a Vauxhall, Suzuki & an AWD Turbo Suzuki powered van, the best advice I can give you is to search the builds on 16vminiclub, you need to decide on which front end you want first. That will determine which subframe options you have.
Good luck with it
Jerry
