Spi Beeping/warning Tone Above 80kph
Posted 24 April 2010 - 05:15 PM
Any help appreciated.
Posted 24 April 2010 - 05:18 PM
Edited by radgator1, 24 April 2010 - 06:19 PM.
Posted 24 April 2010 - 05:23 PM
Posted 24 April 2010 - 06:18 PM
Is it Japanese? if so, probably the catalyst warning buzzer, it is getting too hot.
Yes, it is in fact Japanese. Is it something I should worry about and how can I disable it?
Thanks for the reply!!
Posted 24 April 2010 - 07:04 PM
Hi, from sunny Florida....
Here is a couple of threads that might help you:
http://www.theminifo...x...8&hl=buzzer
http://www.theminifo...x...4&hl=buzzer
I hope that helps,
Ivan
Posted 24 April 2010 - 08:04 PM
I posted this on the regular tech section but haven't gotten any help yet. I have a 1994 SPi new to me. So far it looks like I need a trans rebuild (grinding when shifting to 2nd gear) but there is another problem. A warning tone that goes on and off one speed goes above 80 KPH and always stops when the car falls below 80. Any ideas? Does the car have a speed limit warning system or somethig? I was thinking maybe it is an emissions warning or something.
I dont know if this helps, but several years ago i had a jap import motorbike and it had a red light which came on whenever the speed went over 80kph.
It may be something similar and have nothing to do with the cat temperature sensor.
Chris
Posted 24 April 2010 - 09:33 PM
Chris
Thanks again folks. My car is supposed to be a 1994 so if correct it shouldn't have that sensor. I guess its time to look under her. If it has a beep over 80kph you would think all the other Japan import SPi's would have this as well. I need to get to the bottom of it though because it is annoying as hell.
Posted 25 April 2010 - 10:15 AM
Posted 25 April 2010 - 02:36 PM
The sensor is there for a reason, there could be something wrong with your engine...running rich, burning oil etc etc, just disconnecting the buzzer isn't really doing you any favours. You need to find out why it is getting so hot!
Had a look under and it doesn't look like the sensor is there at all, but even if it were, not sure the "it's there for a reason" argument holds up since it was only on Japan Spec cars so all the other SPi's and MPi's seemed to get along without it. I'm quite sure my car isn't running as it should and I'll be working on that, but first I need to figure out why it squeals like a stuck pig above 80 KPH.
Thanks again for the help.
Posted 25 April 2010 - 07:21 PM
Posted 25 April 2010 - 07:49 PM
Chris
Is it possible that its been added as an extra whilst over in japan. They seem pretty keen on beepers and the like so it could be a speed warning thats been added separately .
Posted 28 April 2010 - 08:17 PM
