Bonnet Lifters
19 replies to this topic
#16 paul6266
paul6266
  • 482 posts
  • Local Club: Retro Classics
Posted 11 May 2010 - 03:48 PM
surely it creates pressure under the bonnet causing it to lift wont it?
#17 mini-man-dan
mini-man-dan
  • 2,684 posts
  • Local Club: J19 Mini Owners Club
Posted 11 May 2010 - 03:57 PM
Shouldn't do. It will drag air out from under the bonnet, therefore it will cause low pressure under the bonnet if anything, 'sucking' it down.
Can you not just make some from some tube? Or flat plate if you are using hinges?
#18 paul6266
paul6266
  • 482 posts
Posted 11 May 2010 - 04:05 PM
i suppose, i was just thinking cus in a soft top car the air hits u from behind where the air swirls around as it goes over the screen, kinda thought it would cause the same effect.
i would make up some alloy sleeves to go over the studding on the bonnet pin if u know what i mean, i can imagine thats the safer option anyway
#19 mini-man-dan
mini-man-dan
  • 2,684 posts
Posted 11 May 2010 - 04:38 PM
Yeah, that should work pretty well. Maybe add a larger diametre piece of metal on the top of the sleeves to avoid damage to the bonnet, ie spread the weight out a little.
Dan :)
#20 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 11 May 2010 - 04:53 PM
I think I remember reading in miniworld's aerodynamics wind tunnel test that raising the rear of the bonnet does not help to cool the engine, due to the low pressure created behind the raised edge.
Just worth a thought.
I like the look but what minijj said is right, it dosn't aid cooling at all!
