1275 a+ or is it?
7 replies to this topic
#1 dean_chad
dean_chad
  • 733 posts
Posted 13 November 2005 - 08:00 PM
:w00t: hello just a quick 1 i bought a shell with a 1275 a+ engine with it, whats the easiest way to find out if its a genuine a+ engine i.e is there a surton starting letter or number on the engine thanks peoples!!!
(oh and by the way the engine hasnt been used since its had a full gasket set by the previous owner and is up for sale)!
#2 dean_chad
dean_chad
  • 733 posts
Posted 13 November 2005 - 08:04 PM
:tongue:
#3 dean_chad
dean_chad
  • 733 posts
the piccies are pretty shoddy will get some more tomorrow
#4 The Matt
The Matt
  • 17,229 posts
  • Name: Matt
Posted 13 November 2005 - 08:41 PM
Get a close up shot of where the distributor bolts into the block, that's one of the differences to spot! :wink:
#5 Jackman
Jackman
  • 4,053 posts
Posted 13 November 2005 - 09:07 PM
I think its an A. Get some more pics up and will be able to tell better (im going off clutch and dizzy, could be wrong though)
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 November 2005 - 09:15 PM
It's a A+, you can tell from the position of the alternator mount points, and yes 1275 head and block ( two core plugs on the end )
What variety can only be determined by the engine number, check the FAQ'S for this.
#7 Jackman
Jackman
  • 4,053 posts
Posted 13 November 2005 - 09:22 PM
You can see all that from those pics? Your eyes must be good. Well ignore my post then he he i was wong.
#8 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 13 November 2005 - 09:46 PM
As GW said. Also, may be a very eary A+ as it has a diaphragm clutch and not a Verto. But this may have been swapped out at a later date :nugget:
