Mpi Fan Help
22 replies to this topic
#1 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 05 May 2010 - 07:49 PM
I have had my mpi a year now recently the fan will kick in and wont go off until i turn the key off its not getting hot it sits just below the halfway mark so overheating probs at all just seems to cut in when hot then not go off anyone had similar problems?
I used search i tried mpi fan, mpi+fan etc but got this message
Unfortunately your search didn't return any results.
Try broadening the search parameters by searching by different keywords or altering the format of your search.
Remember to use the wildcard '*' to increase the number of matches. Apple* will match 'apple' and 'apples'.
#2 Punts
Punts
  • 137 posts
Posted 05 May 2010 - 08:29 PM
Could be the cooling fan switch or the cooling fan relay.
I would try changing or swapping the relay first, easier than changing the switch.
#3 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 05 May 2010 - 09:20 PM
This is a really common fault with the mpi. There are loads of threads but it'll be quicker to just tell you.
Temperature sender (brown on one by the thermostat) isn't being read by the ECU. Becuase the ECU doesn't know how hot the engine is, it's running in 'safe mode' to stop over heating. Sometimes it's the sensor, but ussually it's the loom. The connector that clips on the sender is rubbish and there's a new connector that rover made (sold by minispares) that has a longer wire longer and has a better connector. Quite pricey for what it is, but it's your best bet. Rover made this because the problem was properly recognised and they sent out a memo and everything.
I had this issue and I replaced the sensor trying to save some cash. It worked for a week for 2 but then the fan kept coming on again and I had to buy the loom. When I use the old sensor it works just fine, so that was a waste of £13!
You need this.
#4 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 05 May 2010 - 10:10 PM
Yes, evanisgreat is correct in diagnosis.
For bed time reading, here is the Rover tech bulletin on ths subject:
#5 Ipod
Ipod
  • 2,024 posts
Posted 05 May 2010 - 10:17 PM
Cool, mine does the same....ooo more money to spend.....doh
#6 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 09 May 2010 - 10:11 AM
cheers peeps :thumbsup:
#7 Ipod
Ipod
  • 2,024 posts
Posted 09 May 2010 - 01:38 PM
Remember wich one it is i showed you, the other day.
But as i aint got my mini here, i dont know where you splice the new lead into the loom??
#8 Ipod
Ipod
  • 2,024 posts
Posted 24 May 2010 - 05:36 PM
Bonjour
Would the above problem by the faulty switch not being read by the ECU, cause engine surge...mine as of late whilst driving in 2nd, seems to be holding back in power and then ok..repeatedly...some days its ok?
It has..
newish plugs..(6 months old correct gap)
just over a year old plug leads
And a same shape (as the standerd) K&N air filter (cleaned and re-oiled about 6 months ago)
Adjusted the tappets about a month ago.
Any help would be great..
(If any mods want's me to start a new thread, please PM me 1st, so i can copy/paste what iv already typed)...thankyou
#9 gronkjor
gronkjor
  • 250 posts
Posted 31 May 2010 - 06:21 PM
Bonjour
It has..
My MPI had the exact same problem. I solved it by cleaning the coolant sensor plug with wires. So try it out! >_<
#10 Ipod
Ipod
  • 2,024 posts
Posted 31 May 2010 - 08:15 PM
Is that the brown one on the thermostat ??
#11 gronkjor
gronkjor
  • 250 posts
Posted 31 May 2010 - 10:12 PM
My MPI had the exact same problem. I solved it by cleaning the coolant sensor plug with wires. So try it out! :proud:
Yes it is.. :unsure: Let me hear what you figure out because I am not quite sure whether it is a lasting solution.
#12 Ipod
Ipod
  • 2,024 posts
Posted 19 June 2010 - 03:37 PM
Ok i fitted the new sensor and cut and replaced the old harness with the new one...
And yup it works, the fan is now only kicking in when it needs to, not all the time.
Also the engine seems to idle better and run better...(the old one must have been telling the ecu somthing) maybe someone could elaberate for me ??
the fix is easy, with limeted amount of mechanical/electical knowlege only took me 40 minutes
All good
Ipod
#13 chrisking2021
chrisking2021
  • 77 posts
  • Local Club: chesterfield
Posted 22 June 2010 - 07:16 AM
All good
Ipod
Elaboration!
If the sensor or wiring fails to the temperature sender it cause the fail safe or limp home mode to activate. This mode causes the fan to run all the time (just in case the engine is overtemp). The ECU also increases the fuel as the engine might be cold (a little like the choke being on) this causes bad fuel economy and more frequent trips to the petrol station. You sometimes see a mod chip on fleebay that states it will increase engine output in seconds for really cheap this is normally a resistor that sits in circuit with the coolant temperature sender and tells the ecu its running colder than it is, thus increasing the fuel. Chances are it wont make any differance to the bhp though.
is this ok for you
chris :(
#14 tahitigirl
tahitigirl
  • 284 posts
Posted 24 June 2010 - 09:40 PM
All I can say is thank you very much for this topic I have found it very handy...as like everyone before I too have had a problem with the fan!
Thank you so much this will hopefully help out Blink and reduce her fuel costs :lol:
#15 Ipod
Ipod
  • 2,024 posts
Posted 24 June 2010 - 09:45 PM
It dont save toooooo much, but runs better lol
