Ford Fiesta 98, Excessive Brake Pedal Travel
Posted 09 May 2010 - 06:29 PM
Posted 09 May 2010 - 06:58 PM
hi, i just replaced the rear brake shoes on me 98 ford fiesta, now have excessive pedal travel, i presume they need adjusting, but how do i do that?? thanks guys.
If I remember right they should be self adjusting (read never works). there should be an adjusting bar which goes between the shoes which will have a ratchet on it. Easiest way to adjust is to put 2 screwdrivers on the inside of the shoes, either side of the wheel cylinder and gently ease apart. If you go to far then just click the ratchet back. If i'm wrong then completely ignore me as its been a long time since I did fiesta back brakes.
Posted 09 May 2010 - 07:42 PM
Posted 09 May 2010 - 07:53 PM
Posted 09 May 2010 - 07:57 PM
good luck
michael
Posted 09 May 2010 - 08:05 PM
Posted 09 May 2010 - 08:19 PM
when i refitted the drum, it was almost impossible to get on, so i knocked the adjuster back a few clicks, until i could just about get the drum back on, i think ill give it a few days and see what happens.... thanks
Posted 09 May 2010 - 08:22 PM
If you don't treat them gently at first then they'll glaze up and not bed in properly, but it sounds like you've done it right so far so let them run in, often it only takes a few miles of use to start getting better.lol, take it easy, ermmmmm.....
Posted 10 May 2010 - 07:43 AM
Posted 10 May 2010 - 08:14 AM
When you had the drums off, was there a bit of a lip around the edge? this is normal due to general wear and can make the drum tight to go on, but then needing adjustment for use. One trick is to carefully grind off the lipped edge without touching the braking surface with the grinder, then adjust the brakes to make a nice snug fit and you should be sorted. If the lip is huge, then the drums need replacing. as no amount of adjustment will give you back the right pedal travel without the cylinders popping and giving you no brakes at all.
On a car that age, it will be well worth bleeding the brakes through with nice fresh fluid anyway! at least you will know the hydraulic system has no air or muck in it and the problem is likely to be mechanical.
Posted 10 May 2010 - 08:36 AM
Posted 10 May 2010 - 10:28 AM
Posted 10 May 2010 - 11:24 AM
Put shoes to minimum adjustment on the ratchet and pawl
Put drums on
Get mate to press pedal (put your head near the back of the car, you should hear the adjuster clicking)
Adjust handbrake cable back up
Try car
Simples.
Yes, you could have a ridge on your drums. If that's the case, buy new drums, they're cheap. The reason there's a ridge is that the drum is worn. It ain't worth the hassle of grinding the lip off.
Posted 10 May 2010 - 11:25 AM
Way I do them is
Slacken handbrake fully off
Adjust shoes so drum just fits over, using 2 screw drivers.
The adjusters are crap, so either fit new ones or do my little trick. A dab of weld on the adjuster mechanism so it wont else adjust backwards. This stops the rachet mechanism slipping back and loosing adjustment as the blob of weld stops it.
Refit drums, press brakes afew times and adjust handbrake.
Works for me!
Jordie
Posted 10 May 2010 - 11:30 AM
