Ford Fiesta 98, Excessive Brake Pedal Travel
20 replies to this topic
#16 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 10 May 2010 - 11:50 AM
Under the handbrake lever gaiter, there is an adjuster, I think you'll need a 10mm spanner. to be honest, I can't remember that well! :lol:
#17 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 10 May 2010 - 06:46 PM
yup 10mm spanner or a long socket if you can get in.
Slacken it right off,adjust the shoes, press pedal to centre them afew times and then adjust handbrake up.
Worked on our fiesta, the blob of weld is a cheap fix if you dont have new automatic adjusters.
#18 davidv
davidv
    Flowers of JOY.
  • 416 posts
Posted 10 May 2010 - 08:37 PM
Hope you have fixed them.I had no back brakes on one of my old cars used the gear box to stop fast.
Are advice will fix it in the end.Keep working on it. :lol:
If a cylinder has gone you will see wet stains and fluid loss in chamber.
while at it change all the brake pipes=joking. :o
Dragsters use a shoot to help stopping like old draws Size 20 plus on a Tow bar.
#19 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 10 May 2010 - 08:46 PM
Slacken handbrake cable adjusment right off
Put shoes to minimum adjustment on the ratchet and pawl
Put drums on
Get mate to press pedal (put your head near the back of the car, you should hear the adjuster clicking)
Adjust handbrake cable back up
Try car
Don't do this, it won't work (20 years of motor trade workshop experience tells me this) and you'll be back to a rubbish pedal again.
Yes, you could have a ridge on your drums. If that's the case, buy new drums, they're cheap. The reason there's a ridge is that the drum is worn. It ain't worth the hassle of grinding the lip off.
Do this then manually overide the adjusters as i mentioned before, or let the shoes wear in now if the lip is only small.
#20 samsfern
samsfern
  • 5,243 posts
Posted 10 May 2010 - 08:50 PM
there was a lip, but not excessive in my opinion, think ill give them a while and see what happens
#21 samsfern
samsfern
  • 5,243 posts
Posted 12 May 2010 - 08:10 PM
thanks guys, its slowly getting better now, had another problem today with the brake lights sticking on, damn switch, sorted now though, thanks for the help
