Minisport 998 Stage 1kit Needle Problems
Posted 11 May 2010 - 10:23 AM
wander if any 1 can help. I've got a 1981 mini HL running bog standard 998 with a mini sport stage1 kit on it. I fitted stage 1 kit and had problem where it was running out of fuel at 60 mph! I have to turn mixture up so rich it struggles to idle and at idle it starts to flood but will run over 60 mph but still lean. I look at a post on minifinity which said it was the wronge carb needle and recommended an AAA needle or AAU needle. I brought both these needles from himley. I tried both needles and are too rich at top end. E.g flooding. The needle I got with stage 1 was an AAV.
Has anyone got any suggestions as to what needle would be best?
Mark Butcher
Posted 11 May 2010 - 11:28 AM
Posted 11 May 2010 - 11:41 AM
rolling road?
there was considering haveing it rolling roaded but it's finding one near me! As a mecanic I'd like to think I'd be able to get it right me self!
Posted 11 May 2010 - 11:49 AM
Posted 11 May 2010 - 01:57 PM
Posted 11 May 2010 - 02:07 PM
IMO a rolling road is a real must after fitting a stage 1 kit , it will ensure your fueling and overall set up are spot on , something you cant always get with a colourtune or similar
ok mate thought the answer would be to have it set up on rolling road!
Posted 11 May 2010 - 02:09 PM
Lol I know what u mean! The nearest to me is mini sport and that's bout 2 hours away!im after a rr session aswell. i found that after my stage one was fitted, the needle sent by minispares just wasnt right. i had to change it aswell. my nearest rr that deal with minis is about 180 miles away...lol
Hi
Mark Butcher
AAA or AAM should suit your set up I would of thought. What carb is it on these? Its been a while
I dont know how many mini specialists there are in Leicester but I always used Jonspeed in Nuneaton, Warwickshire. Always seemed quite happy to give advise over the phone. Number is on the website here http://www.jonspeedracing.co.uk/
Posted 11 May 2010 - 02:13 PM
I tried an AAA needle but was way to rich! But not tried AAM! Thanks for that I might give them a ring! Cheers sorry I'm running a HS4 carbHi
Mark Butcher
Edited by Butcher HL, 11 May 2010 - 02:18 PM.
Posted 11 May 2010 - 02:36 PM
Mark Butcher
No probs. What area of leicester are you in? Trying to think of someone else in the area that might be able to help you out further
Posted 11 May 2010 - 02:38 PM
Mark Butcher
Hi,
The AAM is slightly richer than the AAA. I have been having some problems with the fueling on my 1981 998. I have just bought a AAU. Waiting for delivery. Will let you know how it gets on.
Good bit of kit to look at.....
http://www.mintylamb.co.uk/suneedle/
If you click on your desired carb (HS4 in this case) it will give you a list of needles which you can compare. Might save you a bit of cash on the rr.
This is a direct link form sucarbs.com so its legit.
Posted 11 May 2010 - 04:36 PM
Mark Butcher
Live Old Dalby Mate so nearer to melton mowbray really mate
Posted 11 May 2010 - 04:44 PM
1984 ..998 stage one freeflow manifold, K&N element filter in drilled airbox...HS4..fixed jet AAA needle mixture set to 2.5% @ tickover
1989..998 stage one freeflow manifold, K&N element filter undrilled airbox....HS4 waxstat AAU needle mixture set to 2.5 % @ tickover
1990..998 + 40 thou, LCB, K&N cone filter element ..HIF38 AAM needle , mixture set to 2.5 % @ tickover
Edited by lrostoke, 11 May 2010 - 04:46 PM.
Posted 11 May 2010 - 04:54 PM
Fitted 3 stage one kits
Hi,
How do you calculate the percentage of CO?
Posted 11 May 2010 - 05:28 PM
