Spot Welding sills
Posted 15 November 2005 - 09:17 AM
Is it just a case of drilling a hole in one of the panels and welding thrugh that n to the bit the the panel is attaching too?
hope that makes sense!!
Posted 15 November 2005 - 10:01 AM
and i dont recomend drilling a hole and filling it with weld, though in theory it would work if done propperlly
Posted 15 November 2005 - 10:24 AM
If not what do they do?
Posted 15 November 2005 - 10:30 AM
I dont weld so cant give any more advice then that. But when you work it out, i know where to fetch my mini
Posted 15 November 2005 - 10:54 AM
i cant weld.........yet
i might try and teach myself though
Posted 15 November 2005 - 02:05 PM
might get one as they look well easy to use!
http://cgi.ebay.co.u...1QQcmdZViewItem
Posted 15 November 2005 - 02:14 PM
Posted 15 November 2005 - 02:20 PM
Basically, you hold your nozzle so the wire is going to come out, and hit the lower panel straight through the centre of the hole on the upper panel. Easiest way to do this is by first donning a pair of welding gauntlets, then holding the Mig torch near the nozzle with one hand, the other hand on the trigger.
This way, you can make sure the wire willgo where you want.
Once the weld has started, and is working, draw back, and with a single circular motion (again, using the hand near the nozzle to guide it), basically fill in the hole.
Done properly, it is easilly as strong as a spotweld - in fact, possibly stronger.
Spotwelds are easy to screw up by an amateur. Too little current and the weld will fall apart, too much and you 'sink' into the metal weakening it.
I do have a hand-held spotwelder that i use for 'external' seams - a-panels, sill seams, wing tops, etc. But the plug welding technique is always used when i replace sills (you won't find cover sills on any mini of mine :wink: ) for welding the 'lower/inner' part of the sill to the floorpan.
Posted 15 November 2005 - 02:39 PM
Posted 15 November 2005 - 04:26 PM
MOT regulations now state that welds must be continuous, so in effect a seam weld for replacement sills.
Posted 15 November 2005 - 04:31 PM
Posted 15 November 2005 - 04:35 PM
Posted 15 November 2005 - 07:43 PM
Do the job properly, and no MOT man will fail it. Basically, if it looks original (original sills) then it'll pass.
I've done three minis in the past four years welding the sills properly. Last one, I even cut out and replaced the inner sil (ok, techically the outer floor pressing) from the doorstep right down to the horizontal of the floor. With a new sill welded over the top, with what looked like factory spotwelds, and the MOT tester commented on how solid the mini was, and how he hadn't seen one in years with the original sills.
I simply kept my mouth shut.
Incidentally, each time it's been a different MOT tester - so no favouritism there!
Posted 16 November 2005 - 02:08 AM
Al
