Cigarette Lighter Wiring.
17 replies to this topic
#1 fraggle_cooper
fraggle_cooper
  • 139 posts
  • Local Club: Welsh Rarebit Minis
Posted 14 May 2010 - 06:27 PM
just a quickie to see the best way of wiring up a cigarette lighter in a 1998 MPI?
will it just be a case of switched live and an earth?
thanks.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 May 2010 - 06:34 PM
yes
#3 fraggle_cooper
fraggle_cooper
  • 139 posts
Posted 14 May 2010 - 06:47 PM
lol, simple answer :withstupid:
thanks :bah:
#4 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 14 May 2010 - 07:14 PM
is that for the sat nav you need for l2b?
#5 Mattl
Mattl
  • 588 posts
Posted 14 May 2010 - 07:52 PM
needs to be fused as well remember
#6 josh.evans
josh.evans
  • 1,439 posts
Posted 14 May 2010 - 07:58 PM
i have done mine to the same fuse as the car radio
#7 captainjack15
captainjack15
  • 3,925 posts
Posted 14 May 2010 - 08:01 PM
I did the same :bah:
#8 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 14 May 2010 - 08:18 PM
I'm trying to find that Minimag 10min tech article where they show you how to install one
I'm sure they mention it needs to be fused aswell, not run straightoff
#9 Kam
Kam
  • 4,140 posts
Posted 14 May 2010 - 08:27 PM
March issue, green clubby with BLOW ME title on front, I think its 2010? :withstupid:
Errrmm, yeah, I've thrown my copy away! Anyone got a spare..... :bah:
#10 M44K TS
M44K TS
  • 3,104 posts
Posted 14 May 2010 - 09:24 PM
Just remember, centre pin is positive, outer pin is the earth.
#11 ste88
ste88
  • 258 posts
  • Local Club: LCMOC
Posted 15 May 2010 - 12:56 PM
i think mine shares the permanent live with the radio, straight from the battery with an inline fuse near the battery end
#12 pauly_boi
pauly_boi
  • 213 posts
Posted 15 May 2010 - 04:57 PM
even if you jump off the radios harness fuse it to be safe. Ive seen so many cars come into my shop with broken radios due to them adding ciggy lighters and melting through the wiring harness
#13 fraggle_cooper
fraggle_cooper
  • 139 posts
Posted 15 May 2010 - 06:18 PM
it is for a sat nav actually hahh,
just going to tie it up under the dash out of sight as it wont get used often.
i hadn't thought of fusing it..good idea!
i'm sure there is a spare slot or two in the fusebox that i could use
what is the best for the live?
i was thinking of tapping into one of the ignition as i ididn't like the idea of using the radio one,
or would that be safe enough?
#14 Brams96
Brams96
  • 2,308 posts
Posted 18 May 2010 - 06:08 PM
I ran a wire from the fusebox from the 3rd connector down on the left (as your looking at it) which connects to an inline fuse then to the socket. The earth just goes to a M5 bolt I mounted under the dash for the radio etc.
#15 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 19 May 2010 - 11:54 AM
I used a 5 pin relay and took a live from the starter solenoid. I used an ignition live to switch the relay to when I switched off the engine the 5th pin on the relay became live. I then put a special timing circuit between the 5th pin and my interior lights so when I switched off the engine my interior lights come on for a short time. It's very nice in the dark.
