Laser Cutting
Posted 16 May 2010 - 12:36 PM
Jon
Posted 16 May 2010 - 12:43 PM
Posted 16 May 2010 - 12:44 PM
I am able to offer laser cutting in steel up to 12mm thick. I can do one-off items and small batch jobs as well as larger orders. Detailed drawings or templates are required and prices are very reasonable. If you require anything please drop me a PM and we can discuss your requirements.
Jon
Posted 16 May 2010 - 12:49 PM
Where you from john, thinking of haveing some letters laser cut into a mini rear valance if this is even possible, thanks.
Based in Lincolnshire but I out source the cutting, sadly I can only get stuff done on flat steel at present and aluminium, but need to check on the thickness of that as I cant go as thick but thinner gauge not a problem although they cannot do real intricate work on ally as it tends to blow easily.
Posted 16 May 2010 - 12:51 PM
That's interesting, what about thin stuff, plaggy 'n aluminium? what size is the cutter bed & will a hpgl file do?
Jon
See abouve for materials, bed i believe takes an 8x4 sheet of steel/ally. Will check on the file type but think they accept most types. If not a simple paper drawing with all dimension on can be scanned and sent to me or even mailed if you want to go real old school lol
Posted 17 May 2010 - 08:51 AM
Rich
Posted 17 May 2010 - 11:20 AM
Posted 19 May 2010 - 10:33 PM
Jon
