The Mini Failed It's Mot
17 replies to this topic
#1 mdickson
mdickson
  • 217 posts
  • Local Club: SMAC
Posted 22 May 2010 - 08:43 PM
Here is what the nice gentleman found.
Test class:
IV
Reason(s) for refusal to issue Certificate
Nearside Headlamp aim too high and too far to the right. (1.6)
Offside Headlamp aim too high and too far to the right. (1.6)
Offside Headlamp insecure (1.2.4b)
Nearside Rear Braking system leaking (3.6.A.1)
Rear Rear brake application uneven (3.7.A.5c)
Nearside Rear brake recording little or no effort (3.7.A.4a)
Nearside Rear parking brake recording little or no effort (3.7.A.7a)
Parking brake efficiency below requirements (3.7.A.9/10)
Advisory Notice issued
Slight play in offside steering
Slight movement in front subframe mounts
Surface corossion to most brake pipes
Windscreen washers poorly aimed
Oil leaks
Underside of vehicle at various stages of corossion and repair and heavily undersealed in places
Rear exhaust mounts perished
Non standard exhaust system fitted
The thing which I was surprised with was the aim of the headlights being a fail point. I think I may need to ask them to adjust them prior to the retest.
So some jobs to be done very quickly.
#2 Scallywag630
Scallywag630
  • 2,850 posts
Posted 22 May 2010 - 08:50 PM
Don't get disheartened, its not that much. Maybe a rear wheel cylinder, beamset headlights and secure one, and sort out handbrake.
#3 mk3cortina
mk3cortina
  • 677 posts
Posted 22 May 2010 - 08:51 PM
i didnt know you werent supposed to have 'heavy' amounts of underseal. bit of a weird one.
#4 chipster196
chipster196
    Destruction Daddy!!
  • 286 posts
  • Local Club: JKSA
Posted 22 May 2010 - 08:55 PM
ive got a non standard exhaust and it was never mentioned on an mot... new wheel cylinder, adjust shoes, sort headlights and your away again :dontgetit:
#5 Jet_black
Jet_black
  • 325 posts
Posted 22 May 2010 - 08:58 PM
Could have been worse, never heard about the non standard exhaust in an MOT before.
#6 huntface
huntface
  • 711 posts
  • Local Club: LSMOC
Posted 22 May 2010 - 09:16 PM
I think he's saying 'bet there's some nasties under there'.
#7 MiniAlex
MiniAlex
  • 734 posts
  • Local Club: Mini's N Oatcakes
Posted 22 May 2010 - 09:24 PM
I've just replaced my rear wheel cylinders today! Leaking, that's the reason my breaks weren't very good.
It didn't take long to change at all, and it's pretty easy to get the head lights adjusted.
I took my car for it's mot and they never said anything about the non standard exhaust. It's a stainless sytem with a Fletcher DTM on. But I do still have the cat on it....
I got told about corrosion to my break pipes, he said they need to be changed one day but serious yet. Also I was told that there was sings of corrosion underneath but I expected that for a 15 year old car!! Anyway, you should be fine. I would get the adviosorys sorted aswell tho :dontgetit: Because things can only get worse haha
#8 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 22 May 2010 - 09:51 PM
Martin - head up mate :D
Thats mainly headlights and possible rear brake cylinders and shoes
Nothing major, dont worry about the advisories :dontgetit:
#9 samsfern
samsfern
  • 5,243 posts
Posted 22 May 2010 - 10:01 PM
Oil leaks
its a mini :dontgetit:
#10 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 22 May 2010 - 10:20 PM
Oil leaks
its a mini :D
+1 :dontgetit:
#11 MiniAlex
MiniAlex
  • 734 posts
Posted 24 May 2010 - 08:16 AM
Oil leaks
its a mini :withstupid:
+1 :P
+ most minis on the road :P :thumbsup:
hahah. i got worried about my tiny oil leak but it's a mini and it's only marking it's spot!
#12 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 24 May 2010 - 08:26 AM
My mini doesn't leak - maybe it's broken?
#13 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 24 May 2010 - 08:31 AM
haha proberly have you got any oil lol mine had a advirsory for a oil leek found out there was 3 pints to much oil in the engine so was coming out of the dipstick all sorted now :P
#14 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 24 May 2010 - 08:38 AM
My Mini doesn't leak either, but then again...it doesn't have any fluids in it, at all!
I've had experience with 3 minis so far, all have leaked oil haha.
MOT doesn't sound too bad sir. Change the bits you need to and waxoyl the underside to prolong its life :P.
#15 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 24 May 2010 - 08:47 AM
Or you have run out?! lol
