Keeps Stuttering When Going Up And Down Hills
19 replies to this topic
#1 Stu 91
Stu 91
  • 20 posts
Posted 23 May 2010 - 11:22 AM
I really need help!
When ever i go up and down hills the car starts stuttering really badly. It's so bad the whole car is really moving and when i'm goin uphill it starts to loose power. But when the cars on flat ground its fine :dontgetit:
Its also started cutting out when i slow down like at a junction.
What can the problem be?
#2 minimalal
minimalal
  • 222 posts
  • Local Club: Eastbourne
Posted 23 May 2010 - 11:25 AM
is your car an automatic?
and if not when you change down going up a hill does it still stutter?
#3 Stu 91
Stu 91
  • 20 posts
Posted 23 May 2010 - 11:30 AM
the cars a manual
if im going uphill and it happens i've tried changin down a gear but it seems to loose a lot of power and almosts stops like its gunna stall.
#4 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 23 May 2010 - 01:00 PM
Low fuel level? (seriously).
Or maybe you've some dirt in the tank?
#5 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 23 May 2010 - 01:09 PM
im thinking along the lines of fuel, either in the float bowl, or in the tank, or a lazy pump that doesn't like gravity!
#6 Stu 91
Stu 91
  • 20 posts
Posted 23 May 2010 - 01:56 PM
The fuel tanks three quarters full and when it stutters it sounds and feels like something is hitting the clutch pedal but there nothing on the interior hitting the pedal. The noise also happens when you change gear. New clutch fitted a couple of weeks ago.
#7 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 23 May 2010 - 02:20 PM
So it's a knocking, not a stuttering?
Have you checked the engine mounts and steadies. Open the bonnet, grab the top of the engine and rock it back and forth, does it move?
#8 Stu 91
Stu 91
  • 20 posts
Posted 23 May 2010 - 04:21 PM
Its knocking and stuttering.
The engine moves a little but would that affect the clutch pedal.
#9 Stu 91
Stu 91
  • 20 posts
Posted 26 May 2010 - 08:41 PM
Changed the fuel pump and the stuttering is still happenin >:P
but its on flat ground aswell as hills now
#10 1984mini25
1984mini25
  • 8,784 posts
Posted 26 May 2010 - 08:45 PM
If it's misfiring under load I’d check the engine electrics, and more than likely swap the coil at the same time.
#11 Stu 91
Stu 91
  • 20 posts
Posted 26 May 2010 - 08:56 PM
only recently changed the coil and the rotor arm, condenser etc
the problem seems 2 be gettin worse
#12 booton
booton
  • 913 posts
Posted 26 May 2010 - 09:19 PM
which carb do u have,
have the cheacked the float to see weather is adjusted properly.
when going down hill if u take your foot of the accerator does it judder then,
#13 The-Womble
The-Womble
  • 646 posts
Posted 27 May 2010 - 12:16 PM
I'm having almost the same problem at the moment! Going up steep hills it'll just keep cutting out (no fuel), and seems to be ever so slightly juddering going down hill or driving at a consistent speed. I've been blaming a faulty fuel pump (which it might be), although if its the same problem as you and you've changed your pump maybe its not.... ;D
Someone else suggested that maybe the pump has just sucked up some crap from the bottom of the fuel pump and is partially blocking the pump..?
Let me know if you get it sorted!
#14 Dave33
Dave33
  • 222 posts
Posted 28 May 2010 - 04:58 PM
Have you checked point gap,you could try swapping old points and condensor over see if it helps.
Im assuming plugs are all ok and gapped?
Remove a plug and see if its getting wet(an indication of a weak spark)if only one is different then its the plug,cap or this lead braking down.IF they all are it could be the coil(is this getting hot?)breaking down,or its a dizzy prob.
Was it previosly ok and this has just started happening?
DAve
#15 Guest_goldjothi_*
Guest_goldjothi_*
  • Guests
Posted 28 May 2010 - 05:02 PM
i m thinking along the lines of fuel, either in the float bowl, or in the tank, or a lazy pump that doesn't like gravity!
