Keeps Stuttering When Going Up And Down Hills
19 replies to this topic
#16 Stu 91
Stu 91
  • 20 posts
Posted 01 June 2010 - 09:34 AM
The problem is solved!!!!! :unsure:
Changed the fuel pump and did the timing and now its all good in the hood! :proud:
#17 tom's mini mayfair
tom's mini mayfair
  • 75 posts
  • Local Club: Not a member yet
Posted 01 June 2010 - 09:10 PM
I've got a similar problem, but its all the time! Its not reving properly, it runs fine at low revs but when you rev a lot it feels like its trying but theres no power there and when you pull up at a junction it wants to cut out. The car has been stored in the garage over the winter so could it be anything to do with that? I also had some welding done in the boot so the tank was removed, could it be anything to do with that?
Any help would be great because i really dont know what to do
#18 Beccahh-hhh
Beccahh-hhh
  • 90 posts
  • Local Club: Mini's Around Dereham / SCMC
Posted 05 June 2010 - 07:42 PM
I've also got a similar problem with my auto mayfair....... keeps spluttering, especially when going uphill, even slightly.. it sometimes helps if you let off a bit, then slowly accelerate. Also, when you stop at a junction, or traffic lights etc, the engine cuts out.
I just got the car today, and its the first time its had a proper run in a while (high wycombe to dereham).
I dont really know much about cars, so any help would be greatly appreciated :turtle:
#19 Pauly
Pauly
  • 4,213 posts
Posted 05 June 2010 - 09:02 PM
Could have disturbed some crud at the bottom of the tank and its been sucked into the carb, meaning the flow of fuel is limited so runs fine at idle then starts to lean off at top end.
I dont really know much about cars, so any help would be greatly appreciated smile.gif
Sounds like timing to me, check your dashpot oil and mixture aswell
#20 Beccahh-hhh
Beccahh-hhh
  • 90 posts
Posted 06 June 2010 - 10:47 AM
thanks.
how would i go about sorting the timing?
Edited by Beccahh-hhh, 06 June 2010 - 10:48 AM.
