Is there any vauxhall engine conversion that doesn't require any bulkhead mods ????
Which Engine?
stonie110
, May 24 2010 05:51 PM
1 reply to this topic
Posted 24 May 2010 - 05:51 PM
Posted 24 May 2010 - 06:09 PM
You can modify the gear linkage to remove the need for welding in a big box. TerryG on 16v mini forum has s few piccies showing this. You'll still need a hole for the rod to pass through though, unless there's an optionto use the cable type gear change.
