Towing A Trailer Tent
Posted 27 May 2010 - 10:44 AM
Does anyone do the same, just wondering how they tow behind a mini, its a 998 engine with stage 1 kit
Posted 27 May 2010 - 10:50 AM
Posted 27 May 2010 - 10:52 AM
Posted 27 May 2010 - 10:55 AM
Posted 27 May 2010 - 11:01 AM
Posted 27 May 2010 - 11:32 AM
This is interesting
http://www.ntta.co.u...ion_plates.aspx
Now from that website it states this, which may just be a safe guideline not a legal requirement.
Type 01: unbraked trailers - max. 750kg gross trailer weight or half the towing vehicle's kerb weight - whichever is less. By that guideline you would only be towing 319kg
Weights
Kerb weight:
Saloon (rubber cone suspension):
Manual transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 638 kg
Automatic transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 658 kg
Saloon (Hydrolastic suspension):
Manual transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 679.5 kg
Automatic transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 699.3 kg
Estate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 686.7 kg
Van . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 621.5 kg
Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 622.4 kg
Maximum towing weights:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 404 kg
Estate, Van and Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 303 kg
Maximum towing hitch load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 kg
Maximum roof rack load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 kg
Edited by lrostoke, 27 May 2010 - 11:40 AM.
Posted 27 May 2010 - 11:42 AM
Edited by mini_stella, 27 May 2010 - 11:43 AM.
Posted 27 May 2010 - 11:48 AM
the rule for legal purposes is the trailer loaded has to weigh less than half the car unloaded or 750kg whichever is less got that from dvla when i used to tow alot (not with a mini) this is after the license changes in 1997 i beleive but havent looked it up in a long time and dont know about before that and also dont know what is safe to tow with the car750kg is legal limit, but your car will have a specified towing limit set by the manufactorer in the case of a mini I think its 404kg
This is interesting
Weights
Kerb weight:
Posted 27 May 2010 - 12:22 PM
Posted 27 May 2010 - 01:23 PM
Edited by bmcecosse, 27 May 2010 - 01:23 PM.
Posted 27 May 2010 - 02:33 PM
Posted 27 May 2010 - 02:38 PM
sorry to hijack the thread but im thinking about starting motocross again so where did you lot get your towbar from and also twrminisport what sort of trailer do you use to tow your bikes with cheers
i got my towbar from ebay A1 towing iirc
GL1
Posted 27 May 2010 - 02:39 PM
Edited by PhilipGCaldwell, 27 May 2010 - 02:39 PM.
Posted 27 May 2010 - 02:41 PM
Posted 27 May 2010 - 06:11 PM
That said the chances of ever being stopped and this brought to light ar slim at best
