Year: 1990
i was replacing my tie rods, because they were both looking as straight as roundabouts!
i managed to remove the passenger side easily enough. but when it got to the driver side the rear bolt (closest to the wheel) was seized solid. i tried hitting it with a hammer whilst turning the spanner. cans of wd40 soaked into it. i even resorted to cutting the tie bar in the hope that the bolt head would be left with a bit of clearance and i could lever or hit it out. the tie bar came off and the bolt was left, tho it still would move, not with more wd40 or no matter how hard i hit it.
so i have resorted to grinding the head off the bolt of, so that i can just hammer it through - still doesnt move.
the only thing left i can do is drill it out. the only problem is that the access is a bit awkward and i would like to do it very accurately. i think i may do more damage by drilling it. the other this is that i dont have a ball joint separator so i cant even remove the wishbone that its attached to, and do the job in the garage.
has anyone got any ideas.
other than bleeding the brakes this is my last job on the car before it is roadworthy, so its stopping it being drivable, please help.
heres a picture if that helps
