Front Tie Rod Removal
17 replies to this topic
#16 Cooperman
  • 23,313 posts
Posted 05 June 2010 - 05:32 PM
The reason for fitting the bolt downwards is a safety critical thing :) You don't want it dropping out as you drive along :turtle:
I think every rally car I've ever seen has the bolt pointing upwards so that a bent tie-bar can be changed in a few minutes at a service point. I used to drill and split pin the bolt and use a castellated nut years ago, but nylocs are so effective now that I just use one of those, then distort the thread with a punch (lock-peening) and I've never had any problems. A bigger problem has been the nut at the front of the tie bar and I've seen a few of those ome loose when rallying in the forests. Again, a castellated nut and spilt pin is the correct way to prepare the car.
#17 samsfern
samsfern
  • 5,243 posts
Posted 05 June 2010 - 06:36 PM
i fit the bolt downwards, which i can still do with everything in place, and use both a spring washer and a nylock nut, job done :turtle:
i usually use both a nylock nut and springwasher when i undo a nut on the lil runt. like to see them come undone by themselves.
also you shouldnt reuse nylock nuts or spring washers :)
Edited by samsernie, 05 June 2010 - 06:39 PM.
#18 MRA
MRA
  • 7,607 posts
Posted 05 June 2010 - 09:59 PM
The reason for fitting the bolt downwards is a safety critical thing :wub: You don't want it dropping out as you drive along :D
Peter,
I wasn't knocking what you do, just pointing out that engineering convention for that assembly is bolt downwards :P
If you look under most if not all modern cars you will see bolts going up hill :D that is the design route for that assembly etc...... :P
