Arches
Posted 18 November 2005 - 01:05 PM
Is there any arches which are a size bigger than SP arches?
Also, This is a bit of a call out to Scurvy.
Dosent he make sportspack arches?
Think he could make a set, but 2cm wider than standard ones, And Without the recess for the side repeator as my car dosent have them?
<|Ben|>
Posted 18 November 2005 - 01:14 PM
Posted 18 November 2005 - 01:17 PM
Posted 18 November 2005 - 01:18 PM
This is them Under a set of Sportspack arches. (Same as mine). Just not big enough :erm:
Posted 18 November 2005 - 01:25 PM
Posted 18 November 2005 - 01:27 PM
Posted 18 November 2005 - 01:28 PM
Posted 18 November 2005 - 02:17 PM
SMB is Smudger's Mini Bits I believe, and Smudger is on here. Try talking to him if you do want some specials.
Edited by Dan, 18 November 2005 - 02:21 PM.
Posted 18 November 2005 - 06:55 PM
hi againHey, I need a set of arches, But i need them to be about 2cm wider than sportspack arches.
<|Ben|>
i make big wider than sportpack arches
again i have spent time and effort to design a kit that is easy to fit with perfect results . and no need for rubber ugly trim.....and NO they are not glued on
they are bolt on perfect fit items
let me know what you think
eddie
Posted 18 November 2005 - 08:13 PM
Posted 18 November 2005 - 09:56 PM
took me long enough to make them and get them perfect !!!!
available in sizes and for clubby and saloon
note the perfect fit AND the shiney paintwork matey ...... i love it !!!!!
Posted 18 November 2005 - 10:00 PM
Posted 18 November 2005 - 10:37 PM
Posted 18 November 2005 - 11:27 PM
hi jThe *only* problem I can see if the same that people come across when welding new panels on, because of the rather large tolerances in the panels, are you going to be able to guarantee such a good fit with all minis?
its another trick of mine that i will show you . took me a while to get this right
but look at the finish
also if another panel fitment is not the same this can be corrected , then again
,when you do stuff like we did at smc its right in the first place.
