Metro 4 Pots
Posted 08 June 2010 - 06:15 PM
at the moment i have some 2 pot standard calipers, i was wandering if me putting on the 4 pots would be a worthwhile upgrade as they are only for solid discs?
i've heard that you can convert them to accept vented discs do anyone have any more info on this?
and what else is neede for the converision would i just need hoses, era caliper bolts, metro drive flange with lugs cut off? and do the discs need to be turned down at all?
thanks!
Posted 08 June 2010 - 06:19 PM
Posted 08 June 2010 - 06:33 PM
I personaly think they are a worth while upgrade for low cost and vented can be a little overkill. They are not the best brake option out there but unless you want to pay £250-£300ish for a pair of aluminium callipers they are worth a go
Posted 09 June 2010 - 07:53 PM
This could be the difference between stopping or running some youngster over
Posted 10 June 2010 - 09:42 AM
I assume with fully working standard two pot calipers and decent pads you should be able to lock the wheels?
If so, what advantage do the metro calipers give?
Also does the extra unsprung weight of the heavier metro calipers have a noticeable effect on handling?
One last question, do the vented disks require maintenance to clear road crud that may get stuck in them?
Posted 10 June 2010 - 11:54 AM
As for handling,yes there heavier,and in theory you want lightness,but in practice driving you wont notice the difference,I think they used to use them on miglias,for those who couldnt afford the alloy type.
The vented discs do not clog up,and they cool down quite quick compared to solid type.wether they give you better braking i doubt it.
If you get some make sure you use a good quality disc like ebc and a decnt set of pads,am using yellow ebc in mine,and i couldnt ask for more,originally had blackstuff and was not impressed.
if you get some secondhand ones,make sure you change the pistons and seals.
Hope this helps
dave
Posted 11 June 2010 - 08:13 AM
Posted 12 June 2010 - 08:22 PM
Solid or vented........ the only action that brakes have is to turn kinetic energy in to heat energy by the medium of friction.... that is the bottom line.
Therefore if you can radiate more heat, or if you have a combination of events your brakes will in theory be better, ie higher friction material, more cooling larger mean diameter more calipers, more discs etc....
Generally on a Mini we can increase the friction but by doing so reduce the low speed braking EBC Greens are in this ball park, we can increase the mean radius by fitting multiple piston calipers, we can extract the "Q" (heat transfer) value or heat value quicker by fitting vented discs......
There are thousands of Mini drivers out in the real world who have fitted 4 pots with vented discs to do just that, and for the majority it wasn't done to look good it was done because it works
Now just going back to my first line, "solid or vented" if you brake hard using either solid or vented initially the brakes should not be any different (if all else is identical) it only starts to show up once the amount of heat "stored" cannot dissipate to the surrounding atmosphere, at this point brake fade occurs and until the vented discs get to a similar point they will continue to work without fault.
I personally know what I would prefer, and please note that unless someone knows different I can't think of a new car with solid front discs fitted
So in essence, whilst I can see what Dave33 meant by his statement above, I hope that I have now explained the main difference between solid and vented discs and the reasons for having them.
Edited by mra-minis.co.uk, 12 June 2010 - 08:23 PM.
Posted 12 June 2010 - 08:47 PM
if brake fade on solid discs occurs so fast why do modern cars not have vented discs on the rear?
Posted 12 June 2010 - 08:53 PM
Posted 12 June 2010 - 09:22 PM
Edited by bmcecosse, 12 June 2010 - 09:22 PM.
Posted 12 June 2010 - 09:31 PM
i also note that bill sollis ran solid dics and vented on his miglia,and couldnt notice any difference braking wise,he used solid in the end as they are quite a bit lighter than vented and this is obviously important on a race car.
I think that in theory vented should be better,by stopping discs overheating but in practice this obviosly isnt the case on a mini according to guy who raced minis at top level for many years.
modern cars are alot heavier and run much larger discs than minis so theres obvoiusly a need for vented here.
as for complicated brake line setup this isnt the case,it couldnt be simpler,and replacing the pistons and seals is not expensive or hard to do.you dont really need a servo with metro calipers,as long as the whole braking system is all working as should be and you use good discs and pads they work brilliantly.
The only downside i can see is like said the fitment of 10" wheels,saying that though im sure miglias use 10" so maybe there is a mod to allow fitment,but they wont fit straight on.
dave
Edited by Dave33, 12 June 2010 - 09:43 PM.
Posted 12 June 2010 - 09:48 PM
I havent tried 4 pots with solid discs,and i know the reason for vented is to allow better heat dissipation.
hth
dave
Interesting...... unfortunately I can point you in the direction of people with road going Minis that have swapped from solid to vented because of brake fade, on a race car using race pads fade isn't such an issue.....
Race pads have a higher co-efficient of friction therefore they have "increased" one of the prime items within the braking system.
in pracrice vented discs ARE better than solid as I said once you get to the maximum capacity for heat, if the solid cannot get rid of the heat quick enough a vented disc WILL help...
to quote "modern cars are alot heavier and run much larger discs than minis so theres obvoiusly a need for vented here." absolutely wrong, heavier cars do need better brakes, agreed, however bigger discs get rid of heat quicker so with your theory they wouldn't need to be vented..... and as you stated they tend to be vented, so bigger and vented discs add 2 pluses to the system.. as I said before brakes have to have the following......
1) A disc of mean area
2) A swept surface area
3) Friction co-efficient (pad material)
4) Number of surfaces
5) Pressure applying them to the discs
6) Number of pistons applying the pressure through mechanical means.
Increase any of the above and you Will increase the performance of the brakes this is simple facts based on dynamic and theoretical testing.
I have fitted more 4pots to 10" systems than I can remember.
I have been running 4 pots with vented discs since about 1987, so I have the experience to know that vented discs are a bonus which cannot be touched by any solid system of the same size.
If you think that by fitting race pads to a road car will improve your brakes, forget it as they take too long to warm up and often don't work unti l they are warm
Edited by mra-minis.co.uk, 12 June 2010 - 09:54 PM.
Posted 12 June 2010 - 10:05 PM
these are designed for race use but can also be used on the road ,they work very well from cold,the only downside is a bit more brakedust than greenstuff.i currently run vented and use this setup and couldnt ask for more.
But for road use with the odd blast are vented really necessary?
dave
Posted 12 June 2010 - 10:20 PM
You could also ask the same for drums...... at the end of the day if you drive within the capability of the vehicle (ie slowly) then no vented are not required, thi sis not a turn around on my part as I will continue to use vented on my own cars and advise customers to follow suit when I feel it necessary, ie high power or simply a fast driver...
