Standard Round Nose?
Posted 13 June 2010 - 10:10 PM
Which engine will fit into a Std Round Nose, as I don't like the extended fronts and not too keen on massive bulges.
Also, does anyone have any figures on how much the engines weigh? Any how much power they make?
I'm thinking maybe a 2L 8 Valve is my best option??
Posted 14 June 2010 - 12:06 AM
Fairly sure (someone please correct me if I am wrong) but you won't be able to get a 2l 8 valve under a standard round nose. You could look at mounting the radiator in the boot if you want some more space. You may have a chance of getting a 2 litre in then.
This link will provide you with some engine stats.
http://www.themininu...ngine_stats.htm
Posted 14 June 2010 - 07:56 AM
I will either buy a subframe or I was thinking of spaceframing the front and getting rid of the subframe entirely. Has anyone done this?
Posted 17 June 2010 - 07:22 PM
If you are keeping the towers (e.g. modifying an existing frame) then you will need to stick with a small block vauxhall engine. That means 1.2-1.6 8 valve. The 16 valvers can be fitted but usually require a small bulge on the driver's side to clear the cam cover. The x18xe1 engine (small block) will also fit with a small bulge however the x18xe won't as that is the larger block (same as 2 litre).
Edited by Owen, 17 June 2010 - 07:23 PM.
Posted 20 June 2010 - 11:34 AM
I'm stuck between Honda B16 or Vauxhall 2.0L 8 Valve.
I'm sure someone on here put a little table up that showed the VTEC as being alot heavier, is that true?
Lee
Posted 20 June 2010 - 01:32 PM
Cheers mate, that's what I thought. How much power do you reckon you can get from a mild tuned 2.0L 8 Valve on twin 40's?
Lee
I would stick with the injection mate. If you get the manifold reversed (so the TB is on the opposite side), fit a decent air filter, exhaust, FPR you should see well over 130 ponies and similar torque figures!
As a rough guide, I took my standard 2ltr 8v up the strip against a 1.8 honda mini (twice with 2 different drivers) and I beat it both times.
Posted 20 June 2010 - 05:07 PM
Posted 21 June 2010 - 07:08 PM
Posted 22 June 2010 - 01:36 PM
could you not fit a redtop in a standard round nose with a removable front and custom sub frame
I think the struggle is fitting the radiator in?
Posted 03 July 2010 - 12:46 PM
Posted 30 July 2010 - 04:44 PM
Cheers,
Kenny
Posted 01 August 2010 - 07:59 AM
With the right exhaust manifold, you'd get a decent rad upfront too. The alternator is the only real issue. Mine pokes through the front panel a little.
Posted 01 August 2010 - 11:33 AM
My C16XE fits under the standard roundnose front, you could just get away without having a bulge in the O/S inner wing I reckon.
You can also fit a C20XE in aswell with a few little mods
Posted 01 August 2010 - 11:39 AM
Posted 01 August 2010 - 12:02 PM
