Twin Tanks?
Posted 14 June 2010 - 09:26 PM
just had a thought tho, i love the twin tanks look. but its very expensive for a right hand tank.
has anyone ever tryed making a pipe from the right side filler cap to the lefty tank so that it can still be used to fill up.
is there a kit for this?
i know theres cheap stick on ones, but im not really up for that.
cheers nick
Posted 14 June 2010 - 09:28 PM
If you can weld well, then its easily doable with a bit of planning.
Posted 14 June 2010 - 09:31 PM
guna have to think before i drill that hole lol
cheers nick
Posted 14 June 2010 - 09:43 PM
Posted 14 June 2010 - 09:48 PM
cheers nick
Posted 14 June 2010 - 09:57 PM
yea, what i was thinking is running the pipe from the right filler cap down a bit, then over to the back of the boot (just behind the rear seats) at a slight angle for a run and into the left tank. i think it could work with alot of planning. just wondered if theres a kit that does it.
cheers nick
I have been thinking of doing the dummy right hand filler cap too. But why would you want it to be able to fill the tank on the left hand side? No real point in doing this I think.
Posted 14 June 2010 - 10:07 PM
i like the twin look, an i want it to work, but dont want to pay £400 ish for a tank, and then have to run pumps pipes and elecys lol
nick
Posted 14 June 2010 - 10:18 PM
Posted 15 June 2010 - 05:39 AM
just buy another tank and cut off the filler neck and re weld it in the right position....
its not that simple as the standard left hand tank has a cut out for the suspension turret and this needs to be taken out as well on the new tank so it will have to be cut and welded which if not one correctly will be dangerous
i have tried to make a tank but i wasnt happy with the result and i am thinking of buying a right hand tank instead of trying to make one
michael
Posted 15 June 2010 - 06:07 AM
Posted 15 June 2010 - 09:13 AM
but i agree there should be someone that makes them cheaper
Posted 15 June 2010 - 02:50 PM
Posted 15 June 2010 - 05:18 PM
Surely it cant be that hard to fabricate one?
That's got to be quote of the day.
In my opinion £350 is bloody good for something with as many curves and angle changes as a RH tank it. I'd love to see someone mass produce a tank of the same quality for less than the Mini Spares one.
Posted 15 June 2010 - 06:09 PM
Posted 15 June 2010 - 06:55 PM
michael
I have seen it done before a few times... it can be done...
i think you should be careful when welding petrol tanks, unless your using a new one, and your welding is good. The gases in a used tank will cause an explosion when you weld! its the gases that are dangerous, even more so than petrol.
If the op is suggesting welding another neck on a left hand tank, then i guess he knows about this....
