Hi just wondering if it it possible?
I have a mk1 mini, with a c16se lump in there at the moment, but i was wondering can i fit a x16xe cylinder head on this lump?
If i can will i need any mods?
If so does any one have any pictures of this conversion?
Any help is appriciated
Is It Possible?
kappa
, Jun 15 2010 10:37 PM
1 reply to this topic
Posted 15 June 2010 - 10:37 PM
Posted 16 June 2010 - 06:46 AM
engine swap, Pistons are different, cut outs for 16v. Also think the crank camshaft pulley is slightly different too. Then you would also need a pedal box as the inlet / throttle bodies would interfere with your brake and clutch master cylinders.
Heres my daily driver atm (C16XE with the bigger ports)
