Drill Rear Drums For Extra Braking
Posted 16 June 2010 - 10:28 PM
and they opinions on them.
i've been told its a good option as it increase the surface area of the drum and reduces the heat and weight thus creating better braking. ( but you would wear out shoes quicker)
your thoughts
Posted 16 June 2010 - 10:43 PM
Posted 16 June 2010 - 10:45 PM
Posted 16 June 2010 - 10:46 PM
Posted 16 June 2010 - 10:49 PM
Posted 16 June 2010 - 10:52 PM
the holes would be more abrasive on the pads.
Posted 16 June 2010 - 10:55 PM
Posted 16 June 2010 - 10:59 PM
as to the heat i think the holes would allow air to flow though the drum cooling it which would greatly reduce the heat build up.
as the whell rotates when driving more and more cool air would cool the drum inside and out.
Posted 16 June 2010 - 11:01 PM
But don't tell anyone else....... as it is a closely guarded secret
Posted 16 June 2010 - 11:02 PM
Posted 16 June 2010 - 11:04 PM
just going to take a while on the old pillar drill lol.
was thinking 5mm hole three accross stagged e.g -
ss .
ssss .
Edited by booton, 16 June 2010 - 11:05 PM.
Posted 17 June 2010 - 08:40 AM
just get wider shoe's and some Mini Fin's
your rear braking is only 25% Ish of all your braking the rest is done on the front where all the wight is going towards!
i could see if you did it on your front's
but then id personal get rid of the drums on front and stick some 4pot 7.5 calipers on they'll stop you (y)
Posted 17 June 2010 - 11:02 AM
but my back brakes are not the best they are fitted correclty and adjusted right, passed the mot etc but they just not good enough.
u said u can get wider shoes didn't know that.
and mini fins are expensive where as i could spend an hour to in the workshop drilling these.
Posted 17 June 2010 - 11:44 AM
Your setup should work no problems.
I'm on drums all round and they were strong enough to stop mine even pulling a trailer.
Like mentioned brakes are biased to the front, you upgrade the rears to much you'll just end up locking up the rear.
Posted 17 June 2010 - 11:55 AM
and i think auto's did aswell
i run drum brakes all round but i hate drums
i don't trust them!! at least with discs if they brake you still have a bit of braking
