Stalling
22 replies to this topic
#16 minicooper1.3i
minicooper1.3i
  • 871 posts
  • Local Club: na
Posted 30 June 2010 - 01:51 PM
Ok. Bear in mind though it could be the wiring instead. Excessive engine rock can put stress on the map sensor wiring and cause it to break down. This can sometimes account for it being fine when driving (engine tipped one way) and conking out when off the throttle (engine rocks to other extreme). New wires can be spliced in bypassing any break areas.
#17 Colin cooper
Colin cooper
  • 157 posts
Posted 30 June 2010 - 04:08 PM
yeh i read about something similar, i'll check the wiring as well. It mainly stalls when i put the clutch in, but yeh i guess that still causes movment.
How many miles has your mpi done? mine is on about 27k, which i thought was very low
cheers,
Joe
Edited by Colin cooper, 30 June 2010 - 04:13 PM.
#18 minicooper1.3i
minicooper1.3i
  • 871 posts
  • Local Club: na
Posted 30 June 2010 - 04:32 PM
Mine had done 32k when I bought it, but now I'm doing 700 miles a week, it's racked right up to 46k :D
#19 njathind
njathind
  • 447 posts
  • Local Club: Chichester Mini Club
Posted 30 June 2010 - 04:55 PM
You think yours is bad, mines about to push 100,000
:D :P :teehee:
#20 Colin cooper
Colin cooper
  • 157 posts
Posted 01 July 2010 - 12:03 PM
i just had a closer look at the mini. Most of the black tape around the 3 little wires going into the MAP sensor had come off, so i wraped them back up with fresh tape. i didn't want to take the sensor out to check it because i don't have a new o' ring for it, so i just unpluged the connector, and brushed it out.
I also took the Inlet air temperature sensor out to take a look, and there was engine oil in the plug on the wire connectors! god knows how that got in there, must of spilled some on it when i did the oil change a few weeks ago. Could oil this cause stalls and kangarooing?
took it for a 15min drive and no stalls, had a couple little kangaroo's, but it felt smoother than before. I think i'm going to give everything a good clean up like minicooper 1.3i did when i get a clear day. Hopefully thats all it needs
Edited by Colin cooper, 01 July 2010 - 12:05 PM.
#21 minicooper1.3i
minicooper1.3i
  • 871 posts
  • Local Club: na
Posted 01 July 2010 - 12:51 PM
Whilst it's off, don't forget to grind / file down the throttle stop piece so it opens fully. I did mine and it does make a difference under hard acceleration.
Good luck with it! :) Any probs, you know where we are :D
#22 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 01 July 2010 - 03:13 PM
Aerosol contact cleaner should be good for this. Be sure to re-insulate / check insulation of electrical contacts so water & other muck don't get back in...
#23 Colin cooper
Colin cooper
  • 157 posts
Posted 06 July 2010 - 09:11 AM
ok nice one. cheers guys
