What Spark Plugs Can You Recommend For A 1380?
29 replies to this topic
#16 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 15 April 2011 - 06:24 PM
For a 1380 with carburettor and 276 cam wich spark plug is the best?
What's the compression ratio?
#17 samsfern
samsfern
  • 5,243 posts
Posted 15 April 2011 - 07:40 PM
id use ngk bp7es, simple.
#18 minifan333
minifan333
  • 72 posts
Posted 15 April 2011 - 08:57 PM
I don't know :|
Is the 1380 stage3 from jonspeed.
#19 liirge
liirge
  • 4,097 posts
Posted 16 April 2011 - 01:38 PM
hmm, well its all to do with the compression ratio. if using the colder BP7's you run the risk of wetting them with the carburettor on start up and idle. I personally think I would go for the warmer BP6 if being used as a daily driver.
#20 Tinkerbelle
Tinkerbelle
  • 246 posts
  • Local Club: Tyred and Exhausted
Posted 16 April 2011 - 02:58 PM
I have run BPR6E on my 1310 with 9.8 c/r and a Megajolt system. These have been fine, but need to be replaced. What is the difference between these and the BPR6ES?
Matt
#21 liirge
liirge
  • 4,097 posts
Posted 16 April 2011 - 03:07 PM
The difference is that you should be using the BPR6ES! The R stands for resistor and this is a requirement when using electric ignition systems like Megajolt! you will probably find that when you swap them over you won't have to change them as often
#22 Tinkerbelle
Tinkerbelle
  • 246 posts
Posted 16 April 2011 - 03:33 PM
Thanks, but I know about the resistive bit. The ones I have been using are! I would like to know what the S at the end means?
Matt
#23 liirge
liirge
  • 4,097 posts
Posted 16 April 2011 - 04:47 PM
ahhh so you are i completely read that incorrectly!
Perhaps the BP6E is an older code, as the S, just means standard copper core. From the data I have at my disposal indicates they didn't make a plug without any reference to the firing end construction (the last letter)
#24 liirge
liirge
  • 4,097 posts
Posted 16 April 2011 - 04:50 PM
Looking further it means it is old packaging!
#25 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 01 March 2013 - 07:33 PM
Sorry to dig this old topic up.
When talking electronic ignition, you mean anything other than points?
Edited by jonny f, 01 March 2013 - 07:33 PM.
#26 Dusky
Dusky
  • 5,322 posts
Posted 25 September 2015 - 10:17 PM
Sorry to bring this up, but what heat range should I get on my 1330?
1330, 35X29mm valves, 643 camshaft, compression around 10.5:1
I've used brisk multispark plugs for the last 200 km without problems, but that is on running in, so I haven't given it real beans.
The heatrange of these plugs is the same as a NGK 6. But I must say they are a bit tucked away in the spark plug hole, so I guess they'll be a tad cooler? ( less flame exposure?)
Glad to hear any advice!
#27 nicklouse
  • 18,655 posts
Posted 25 September 2015 - 10:35 PM
Give them a good run and see.
#28 Dusky
Dusky
  • 5,322 posts
Posted 25 September 2015 - 10:38 PM
Could a plug break after a good run? Or melt?
Don't mind buying new plugs, but don't want to damage the engine :>
#29 nicklouse
  • 18,655 posts
Posted 25 September 2015 - 10:44 PM
Yes and no.
You could if you did a long race on the wrong plugs.
I used to have warm up plugs and race plugs. Left the warm up plugs in once and they were fine for a balls out drag run.
Think they were 5s when I normally ran 8s or 9s.
Go for a blast and have a look.
#30 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Posted 25 September 2015 - 11:26 PM
My 1330 loved the BPR6ET plug. Brilliant things.
