Need More Volume!
Posted 29 June 2010 - 11:23 AM
I know mounting speakers up front is my best bet for increased volume, but i don't want or have a dashboard, so no speakers can go there, i don't want tweets going where my vents currently are, and door mounted speakers aren't to my taste.
Is there anywhere else i could mount a discreet but effective pair of speakers in the front?
If not, could someone recommend a brand of speaker with a higher tolerance for distortion?
Posted 29 June 2010 - 12:31 PM
So if you speakers can put out 50w RMS, but you amp is giving them 100w RMS, your giving them more than they can take and they'll just distort and eventually you'll damage the speakers.
Its not so much the brand of the speakers, its just the RMS rating. Do you know how much RMS you amp is putting out into the speaker?
Posted 29 June 2010 - 12:34 PM
But liek stated above, either way, you need to match them up.
Posted 29 June 2010 - 02:21 PM
However, I do notice something else in your system. If the eights are in the package shelf, and the 6x9's are presumably in a under-seat board, is there any sealed enclosure at all behind the speakers? Especially for subs, the enclosure helps to act as an additional spring keeping the voice-coil of the speaker from travelling beyond its designed range of motion.
Posted 29 June 2010 - 05:40 PM
When you get distortion it usually means the speakers are getting more power than they can handle.
The speakers aren't amped at all, so they're running off the head unit (which i believe is around 50Wx4)
I think this may be the problem. Neither the subs nor the speakers have enclosures. Making enclosures will be my task tomorrow, although one sub is mounted extremely close to the fuel tank, so i'm not sure how i can create a sealed enclosure around both.
Posted 29 June 2010 - 08:06 PM
Posted 29 June 2010 - 09:34 PM
Posted 29 June 2010 - 10:26 PM
No amp could also be the problem. A head unit, especially if it's 50W X4, isn't going to push a sub and give any decent sound. And depending on the other speakers, the HU may not even be enough for them either.
Nah, the subs are connected to an amp (at precisely the right wattage and ohmage), it's the 6x9 speakers that are un-amped
what about making a small mounting bracket for the speakers and mount them fancing down under the dash, if you get what im trying to explain
That's quite a good idea, although there isn't much room around the steering column...
Speakers shouldnt need enclosures
I've had contradictory advice from others here on that matter...
Posted 29 June 2010 - 11:19 PM
Edited by skaterava, 29 June 2010 - 11:20 PM.
Posted 30 June 2010 - 01:44 AM
Alot of speakers require a minimum input just to run properly, so if the H/U isn't providing enough, as has been said that will also leave you with bad sounds.
A half decent 2 channel amp to run your speakers properly aren't too expencive - The fli 2 channel amps have good power for their cost.
Posted 30 June 2010 - 10:18 AM
It depends how many channels the amp is. You need one channel for each speaker and usually to get enough power for a sub 2 channels are bridged into one to run a sub.
The 600W amp is a 4 channel, so if i attach both subs and speakers to that, it would send 150W to each..which wouldn't work.
I also have a 200W, two channel amp lying around, which, like you said, could be attached to my speakers, giving them 100W apiece (much closer to their 125RMS).
Good idea?
Posted 30 June 2010 - 01:57 PM
just a thought
sean
Posted 30 June 2010 - 03:56 PM
Posted 30 June 2010 - 07:29 PM
they do purpose built speakers pods that mount to the inside of the front wheel arch.
also speakers do work better in enclosures, ive tried both, its just a matter of getting the air space right for your speakers
Posted 30 June 2010 - 07:57 PM
2 6x9's with 20-25watts rms ea, thats probably why the sound isn't loud enuff for you and
dist real fast
