i am slowing starting to build up a 7-port motor, and i dont know what carb to get. i will be using carbs for a while untill the engine is paid off, then i will upgrade to a set of jenveys
i know in david vizards book, he had found that the dellortos provide finer fuel atomisation, which is better with the 7-port rather than the droplets from the webers.
David Vizzard to say in Auto Performance magazine, “Dell’Ortos produce truly excellent results...On engines where atomisation is a premium requirement, Dell’Ortos are superior to everything”
MED who are supplying the head, use and only use webers and fuel injection on their 7 port builds, so they must be happy with how the webers perform on them?
i was weighing up the pro and cons of each and came to this:
weber pro:
its a weber!
more widely available second hand
looks better and is more recognisable.
weber con:
more expensive
less adjustment available
less MPG than dell
not as efficient through the bottom and middle rev range on the 7-port
dellorto pro:
cheaper
finer adjustment
finer fuel atomisation, beneficial for the 7-port
better MPG
better through the revs
dellorto con:
not as available
more complicated than the weber in terms of tuning it
considering all of the benefits of the dell's, i havnt seen a single 7-port fitted with them
has anyone got a pair on theirs?
i dont know what to use.
if you were doing a 7-port, which carbs would you use?
a confused adam
Edited by stardude, 30 June 2010 - 12:58 PM.
