Choice Of Carbs For A 7-port Head
#16
Posted 01 July 2010 - 05:07 PM
oh and IIRC the MED head is only sold as a dry deck so don't forget the block work costs.
#17
Posted 01 July 2010 - 05:46 PM
upon talking to them, they said that no work needs to be done to the block waterways, other than the core plug on the left of the engine for the drydeck feed. this is due their head gasket which they provide, which has no waterways through it, so blocks off the waterways in the block.
i think it would be best to get the block waterways plugged, as that means i can use other headgaskets if needed, as well as the fact that i thought the purpose of dry decking was to stop any water contact with the deck/head face??? to prolong headgasket life, aswell as allowign the engine to limp home, without oil and coolant mixign and going into the worng places.
although if i didnt get it machined, if needed i could run other heads.
i will be using this stack and filter kit from them but with a larger filter. this is compatable between the weber 40's and jenveys. link
ohh and if and when i want to go to jenveys i can buy this kit minus the filter, for £950 link
#18
Posted 01 July 2010 - 06:43 PM
I realise that if you went megasquirt then you also get the mappable timing aswell but i was planning on using megajolt anyway so this would make no difference. Sorry to jack the thread but i think it's closely linked.
Cheers,
Andrew
#19
Posted 03 July 2010 - 07:11 AM
What filtration will you get away with or will it just be the mesh covers?
Slightly off topic but can I ask what cam are you planning to use?
#20
Posted 03 July 2010 - 07:52 AM
This is where I've ordered mine from, I will be using a single throttle body which was £10 from the scrappy, I'm Turboing as well.
Dry decking the block is easy, the waterways can be tapped & grub screws inserted, simple & cheap. Dry decking.
#21
Posted 03 July 2010 - 07:54 AM
To be honest, considering the cost of a set of carbs, I'd go straight for injection.
Buy this book http://www.amazon.co...-...9215&sr=1-3
There are cheaper options than Jenvys.
Second that! what about taking a motorcycles engine management system? the pros are, cheap, compact, already sorted on the maps, and yet still lots of tuning options...
it would be pretty easy to do early kawasaki injection, its a 4 injection system, just needs crank angle, engine temp and throttle position and a nipondenso air flow meter with air temp in it, and spits out timing and fueling signal.
next option would be bmw k series injection, but it may need lambda sensor as well.
or for even cheaper, a set of motorcycle carbs until you can afford injection, you should be able to get like a set of kehins from a 1100 cc bike that are essentially tiny su's or a set of flat slides that will sort you out from a breaker for pretty cheap.
#22
Posted 03 July 2010 - 12:49 PM
I did not know the HRE version had to be dry decked, are you sure?
Do all 7-port heads need to be dry decked?
#23
Posted 03 July 2010 - 04:33 PM
#24
Posted 03 July 2010 - 04:53 PM
joining the club eh Phil,
#25
Posted 03 July 2010 - 07:36 PM
Webcon sell the 7 port head with std valve sizes for less than £1000
#26
Posted 04 July 2010 - 10:31 AM
What valve sizes are in the webcon one compared with MED version?
How would the std valve head compare with say a Rally special or clubman MED head for performance?
#27
Posted 04 July 2010 - 01:27 PM
i dont know how the std head flows compared with a 5 port, but MED's trackday/hillclimb head produces 22% more flow, than the best fully modified 5 port head
#28
Posted 04 July 2010 - 09:54 PM
JR
#29
Posted 04 July 2010 - 10:24 PM
#30
Posted 04 July 2010 - 10:27 PM
