12" Banded Steels?
22 replies to this topic
#16 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 10 July 2010 - 06:19 PM
banding alloys is bassically making them in to split rims from what i understand
YetI
No, its chopping the outside rim off, welding a band of steel in the same size as the wheel then welding the outside rim back on, thus making it wider.
#17 sebmini
sebmini
  • 43 posts
Posted 10 July 2010 - 06:59 PM
welding steel to ally??
Edited by sebmini, 10 July 2010 - 06:59 PM.
#18 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 10 July 2010 - 07:36 PM
You can only band steels. Banding is, as has been said several times above, widening steel wheels by cutting them in half and adding extra steel to the middle, then welding them back up again. It's not something to be done at home, and should only be attempted by a workshop properly equipped with some kind of mechanical welder, so the added steel is fixed with a continuous seam weld, otherwise they can be quite dangerous.
#19 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 July 2010 - 09:32 PM
or you can get a wheel rerimmed
this is where you cut the centre off you wheel and refit it to a wider rim
this wheel was a 5.5x14 VW steel wheel, now it's a 8x15 inch wheel
#20 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 10 July 2010 - 09:34 PM
Jeezo never seen that before Bungle!
#21 AdamMk1
AdamMk1
  • 145 posts
Posted 10 July 2010 - 10:01 PM
You can also band ALLOY wheels. As said before though, leave it to a pro.
Edited by AdamMk1, 10 July 2010 - 10:02 PM.
#22 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 10 July 2010 - 10:08 PM
Really? Interesting, I've never heard of that before. That would definitely be for pro's!
#23 Down&Out
Down&Out
  • 4,853 posts
Posted 11 July 2010 - 12:04 AM
Yeah i've seen that before, was gunna do it until i found that banding isnt actually illegal.
