Im gutted did seem to all be going a little too smoothly!
After applying stonechip a couple hours later it as reacted badly and started to peel off!!!
Right i sanded then panel wiped body, Mipa 2K-Transparent Sealer, Mipa 4+1 Acrylfiller HS primer then the stonechip upol gravi tex plus hs
bought all above from same supplier these were the reccomended.
its not all over only in some ares and seems to peel off all the way down to the metal, i will leave it all to dry/react
any ideas?
I was thinking once dryed sand all the way back then follow the same process maybe there was / is some sort of grease of contaminant on the body?!?! god knows
any advice would be appreciated
Edited by Pitcrew6464, 04 July 2010 - 06:48 PM.
