It could be too advanced or too retarded,both will cause overhaeting probs.Well i'll try richening the mixture abit then; but like I said I looked at a spark plug and its was pretty sooty already.
So in terms of timing, what would make it run so hot, so fast? With this be too advanced or what?
I take it the MJ doesnt use a dizzy?
Personally i would try the mixture if no joy speek to whoever set up the base setting for the ignition,im guessing it a 3d mappable type ignition,where you can set the advance curve to whatever you want?
dave
