How Do You Lower An Austin Metro?
#16
Posted 18 July 2010 - 10:41 AM
Like any car a lowered Metty will have a different c-o-g and the front geometry would change more than a Mini's as there's more roll induced camber designed in.
#17
Posted 18 July 2010 - 08:14 PM
That sounds very confusing!!
Thanks for all the responses. I've read them through a few times and I'm pretty sure I understand it.
I think we'll try letting some out, then drive it for a couple days see how it drives/sits then maybe let some more out.
Will I have to let the same amount out of each corner or is it connected?
Is it split just front/rear?
Or does it all become lower?
How would I let the liquid out? Is there some sort of bleed nipple somewhere?
Edited by Lukie-J, 18 July 2010 - 08:16 PM.
#18
Posted 18 July 2010 - 08:21 PM
#19
Posted 18 July 2010 - 09:41 PM
Once you have let the fluid out you will see what we mean, but beware as they get very unstable once below a certain point, let us know how you get on with it though
#20
Posted 18 July 2010 - 09:42 PM
It's your Metro, however it looks like it should be in a museum............ 1982ish and appears to have no rust !!! Surely that's unheard of
1983
#21
Posted 18 July 2010 - 09:45 PM
#22
Posted 18 July 2010 - 10:05 PM
do the fronts first, they are seperate, the rears are intconected and will come down together.
Also another reason not to slam it to the floor is that you can end up with the drive shafts not located in the pot joint enough, and they will pop out.
#23
Posted 19 July 2010 - 07:55 PM
(I'm sure you can get the fluid pumped back in somehow)
Thanks for the help.
So do the fronts first, then the rears; got it.
How do I let the fluid out? Is there a bleed nipple somewhere?
What's the best way to make sure that they're both the same?
I will let you know how we get on. Will put some pictures up soon of it with some 12x6 revo's on
Edited by Lukie-J, 19 July 2010 - 07:58 PM.
#24
Posted 19 July 2010 - 09:30 PM
#25
Posted 19 July 2010 - 10:41 PM
its well nice!!
#26
Posted 20 July 2010 - 12:22 AM
#27
Posted 21 July 2010 - 04:14 PM
Not my car so don't preach to me! just helping a friend out, with a lot of input.
#28
Posted 14 August 2010 - 12:18 PM
Before pictures are on the first page, after pic on the second page.
(ignore the cheap-tint method, I think it's stupid too!)
Decided to take it to a garage to have it lowered with the proper pump thing.
Still got an inch of travel before the bump stops so I think it'll be OK, doesn't look massively different but handles better and will look slightly better (when he eventually gets some 12x6 wheels)
Edited by Lukie-J, 14 August 2010 - 12:19 PM.
