Shortie
254 replies to this topic
#1 superman
superman
  • 736 posts
  • Local Club: Dorset Mini Club
Posted 19 July 2010 - 07:53 PM
Good evening everyone, thought i'd make a start and put up a post on my lastest project, my mate Bertie was selling his unfinised project and after a few beers a deal struck(Bertie drives a hard bargin) after shelling out a mind blowing £50, with a little help from another mate (Dave) the car arrived home
Bertie had already cut the roof off, removed the rear bins cut the rear seat then cut the car in half and removed 18 1/4 inches from the wheel base and welded it all back together thats how the car turned up
I've lost the pictures up to this stage
The first job on the car was to stiffen the shell by putting back all the lost strength
Attached File  Picture_015.jpg   273.81K   127 downloads
i'll post more of the build later........ just a quickie to see what it looks like now
Attached File  Picture_011.jpg   73.88K   166 downloads
#2 amarcd
amarcd
  • 434 posts
Posted 19 July 2010 - 07:56 PM
Looks like a good project, starting at £50 you cant go far wrong! Nice one! :w00t:
#3 superman
superman
  • 736 posts
Posted 20 July 2010 - 08:26 AM
After installing all the box section down both sides, i've fabricated and installed box section across the inside heel board, more strengthing to follow
at this point a quick look over of the shortie revealed a new front end needed,new rear valance and two or three patches in the boot oh and a boot lid
waiting at the back of the shed two front wings and mk1 boot lid......... bonus
Oh at this point it worth mentioning this project will be built with two things in mind, safety and cost, i will not skimp on safety and i will not throw money at this project, i'm going to complete this build with out a second mortgage
check out the mods to the bonnet that came with the car it was totally shot.
Attached File  Picture_020.jpg   439.33K   69 downloads Attached File  Picture_013.jpg   90.72K   92 downloads
More to follow
#4 memad1275gt
memad1275gt
  • 15 posts
Posted 20 July 2010 - 08:09 PM
More to follow
very impresive bonnet, what a bargin for £50
#5 superman
superman
  • 736 posts
Posted 20 July 2010 - 08:24 PM
The bonnett was shot to bits what you can see is a few hours work in the shed one night, i thought if it turned out poop i'd just bin it Attached File  Picture_022.jpg   79.2K   47 downloads
#6 memad1275gt
memad1275gt
  • 15 posts
Posted 20 July 2010 - 08:35 PM
look forward 2 seeing more
#7 superman
superman
  • 736 posts
Posted 21 July 2010 - 06:01 PM
more photos what do you think?
Attached File  Picture_009.jpg   68.44K   90 downloads
Attached File  Picture_023.jpg   183.59K   48 downloads
Can You spot the mods? look carefully you can spot a Ford KA dash in the top photo
Edited by superman, 21 July 2010 - 06:24 PM.
#8 mini-man-dan
mini-man-dan
  • 2,684 posts
  • Local Club: J19 Mini Owners Club
Posted 21 July 2010 - 06:12 PM
Looking cool! I used to have a shorty, but it was much shorter than that. Would say that's a limo shorty... :rolleyes: Certainly will be different! Good luck :P
#9 superman
superman
  • 736 posts
Posted 22 July 2010 - 07:51 PM
Thanks for your comments, mini-man-dan, amarcd i got a lot more piccys to go up heres the lowdown on the above photos
Mk1 boot lid.... handle removed, cable operated, light recesse welded
screen scuttle.... no wipers no washers no holes, new air vents
Dash.... moved to centre clock, ashtray welded, airvents welded, switch panel cut out rounded off and welded,
more Photos
boot before
Attached File  Picture_042.jpg   233.8K   35 downloads
strange bit of metal to be used for new boot floor (it's the spare one only needed the black one)
Attached File  Picture_044.jpg   433.79K   37 downloads
just need to weld it in
Attached File  Picture_043.jpg   223.59K   116 downloads
Edited by superman, 22 July 2010 - 07:59 PM.
#10 superman
superman
  • 736 posts
Posted 23 July 2010 - 07:07 PM
Just for Sam.......
Attached File  Picture_039.jpg   41.3K   101 downloads[attachment=100991:Picture_037.jpg
more to follow enjoy, feel free to add your opinion, good or bad
Edited by superman, 23 July 2010 - 07:11 PM.
#11 superman
superman
  • 736 posts
Posted 03 August 2010 - 08:21 PM
More photos
Attached File  Picture_010.jpg   50.87K   59 downloads
Attached File  Picture_033.jpg   325.52K   33 downloads
progress has been a bit slow .....things should start to pick up a bit now.....time to crack on
#12 Mini-Mad-Craig
Posted 03 August 2010 - 08:32 PM
Simply awesome. I would LOVE a shorty. Keep at it, well done. ;)
#13 superman
superman
  • 736 posts
Posted 05 August 2010 - 06:38 PM
Thanks Mini-Mad-Craig, great comment thanks again
Colin
#14 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 05 August 2010 - 06:55 PM
Wicked been ages since ive seen a shortie project :) and this ones great :mmkay: keep up the good work and the photos coming, oo ooo just once suggestion before you get near paint, in your first photo it shows the new section where the door used to be, down on the floor/inner sill i would used the cross beam and weld it in length ways on drivers and passengers side just adds strength and redigity :P
Edited by Pitcrew6464, 05 August 2010 - 06:59 PM.
#15 superman
superman
  • 736 posts
Posted 06 August 2010 - 07:37 PM
Hi Pitcrew6464, Thanks for comments thats the sort of encouragement we all need to keep going thanks mate.
The seat crossmember has been replaced and also 25x25mm box has been run all along the floor up against the heel board, where the rear seat has been cut back, 25x25mm box welded in under the seat, both of these connected to each other and each section (either side of tunnel) trianglated also a new box section/seat crossmember added to (A) support rear of seat (B) add more strength, the front end of the roof/apron is welded to the top of the steelwork running down the sides of the car, again this a triangulated set up then the roll hoops connected through the roof/apron
God i hope that makes sense
Colin
