1380 turbo?
Posted 25 November 2005 - 02:46 PM
Also i have a full stainless off a metro turbo but the front pipe caught on the bulkhead at the bottom between the subframe. Would a front pipe from avonbar be any different? Also has anyone used a race can on their turbo? Iv got an old R1 can lying round.
Cheers.
Posted 25 November 2005 - 03:48 PM
Perdonally, I'd leave it where it is.
As for exhausts, the Avonbar (or more likely maniflow) down pipe is the one you want. It's designed to fit,so it will.
Assuming that the bike scielencer is the right size tube then I'm sure it will work fine. Not sure what it would look/sound like though.
Wil
Posted 25 November 2005 - 06:20 PM
Cheers.
Posted 25 November 2005 - 07:04 PM
Get your engine up and running and save your pistons for when it needs a rebuild in the future.
Phil.
Posted 25 November 2005 - 07:17 PM
Cheers.
Posted 25 November 2005 - 07:38 PM
For a decent cast Turbo piston i would try the Minispares Mega pistons. Though you'll have to go +.20.
Phil.
Posted 02 December 2005 - 11:45 PM
1380 Turbo if you use the 73,5mm Omegas with an 11cc or 15cc dish, then 26cc head chambers will allow 12 to 16lbs quite comfortably coupled with the extra torque you WILL need a 4 pin diff unless suicide is an option !!
The higher the final drive ration I.E 3.11 is good with 13" wheels and tyres gives good alround traction and top end, just make sure your clutch is up to it !! :grin:
Good luck its worth it .....
Posted 11 December 2005 - 03:41 PM
Alex
Posted 11 December 2005 - 07:05 PM
imho i would shy away from 1380 turbo untill you have sorted the car, also as someone has already stated you would need to machine the chamber and i may stand corrected but i am sure its going to be more than 26cc, having the head reworked is never cheap if done well so again the expence may be an issue
other considerations are going to be what you use the car for? a 1275 may be more reliable than a 1380 in the long run
Posted 11 December 2005 - 09:58 PM
Posted 11 December 2005 - 10:11 PM
Posted 11 December 2005 - 10:33 PM
Posted 11 December 2005 - 10:58 PM
i'm not so sure about all that bore flex talk to be honest, sounds like an old wives tale to me. but we'll see if i decide to go ahead with a 73.5mm bore on my next build.
if it breaks then i'll believe it...lol
Posted 11 December 2005 - 11:07 PM
Hi,What clutch would you run with that MRA?
Alex
I have run several clutches over the years:-
I have a Paul Ivey Race aluminium flywheel (Flywheel 5lbs & backplate weighs in at 1.25lbs) with that I used an orange diaphragm and a race/rally plate
currently I am using an ultra light steel flywheel and backplate with a grey diaphragm and a race/rally plate
I have used sintered plates in all of the above, whilst the "grip" is great the gear changes and start off can be a lot sharp i.e. like a switch - either on or off !!!
You can get used to it !!! But I was at that time using it to get to work in rush hour, my left leg is at least three time bigger now :grin: :grin:
I have been running 1380cc turbo engines since about 1986/7 without any major problems, my first head was an AVONBAR unit which I used for quite a few years,
I say GO FOR IT :grin: :grin: :grin:
