i was looking at buying an r5gtt turbo, and the part number of the later turbo i found was 465367-1/2. is this right?
t2 identification
Leonard
, Nov 26 2005 03:18 PM
8 replies to this topic
Posted 26 November 2005 - 03:18 PM
Posted 26 November 2005 - 04:09 PM
oooh, I know this....
But can't say for sure!
As a visual check; the R5GT should have two studs and two clearance holes in the turbine (exhaust) housing as opposed to the more conventional four (clearance) holes...
Posted 26 November 2005 - 04:13 PM
http://www.turbomini...p?p=vt&tid=3231
Turbominis comes up with the goods again! I just punched the number into the search, and it's come up as deffo an R5GT unit.
Posted 26 November 2005 - 09:36 PM
Like this?? Is there anyway of telling it between a T25 & T2 though?
Posted 26 November 2005 - 11:47 PM
that sure looks like a brand-spanking new R5GT spec T2.
As regards T25 vs T2, they use the same turbine housing interfaces. The T25 has an ever-so-slightly larger compressor housing diameter. the centre housing has a larger flange to accomodate this.
Not easy to tell from a picture. In fact, not easy to tell if you didn't know exactly where to look even if you had one in each hand.
Don't assume that bigger is better though.... Stick a T25 from a 200SX onto your 1293 mini turbo and you'll be slower to build boost than a stock T3.
Posted 27 November 2005 - 01:23 AM
bit O/T but i'm due a new turbo any time soon but i want to stick with a T3. What would you recommend as the best size to go for dave? i'm not too hot on all the numbers and AR stuff.
I seem to remember hoggy or JF are using an uprated T3? or am i confused again
Posted 27 November 2005 - 02:44 AM
was going to answer here, but PM sent instead...
Posted 27 November 2005 - 09:30 AM
cheers dude
