Priming An Oil Pump
Posted 29 July 2010 - 07:22 PM
I have pushed the car backwards in 2nd gear as advised by someone
Is this the right thing to do is there anything I should look for?
Posted 29 July 2010 - 07:27 PM
what engine have you?can anyone tell me how to prime an oil pump
I have in the past removed the oil filter conection pipe and let oil in the hole in the block turning the engine backwards slowly, screwed it all back together and off you go
Posted 29 July 2010 - 08:08 PM
Posted 29 July 2010 - 10:30 PM
Edited by mra-minis.co.uk, 29 July 2010 - 10:30 PM.
Posted 30 July 2010 - 07:24 AM
Assuming it's a new installation, did you prime the pump before installing it? Have you put the O-ring seal between the engine and box? Is the pressure relief valve jammed open? Is the ball-bearing valve in the oil filter housing jammed open?
Lots to check.
Posted 30 July 2010 - 09:47 AM
have you removed the spark plugs ? how long are you cranking it for ?? Have you filled the oil filter ???
plugs are removed and i'm cranking for about 15 seconds, dont want to do it much longer with the new bearings on the cranck only being hand lubed.
Is this a new installation, or has it just not been started for a while?
Lots to check.
yes new installation, did not prime pump before installing, O ring installed, dont know how to tell if the PRV is open but took it apart and all looks well, and i have not checked ball bearing valve as i never knew there was 1, shall check it now but its not just oil pressure i'm lacking its the actual oil itself as i've taken the oil guage off its hose to see if i could get a trickle and nothing. really dont want to have to strip this engine again!
Posted 30 July 2010 - 04:18 PM
Posted 30 July 2010 - 05:05 PM
15 seconds is too short it will be more like 5mins before you get oil pressure up, try putting oil in the filter as well redo the oil pump with oil
i thought 5 mins with no oil arround new shell bearings would wreck them but i'll give it a go, cheers
Posted 30 July 2010 - 05:08 PM
Jordie
Posted 30 July 2010 - 05:18 PM
Posted 30 July 2010 - 05:19 PM
Posted 30 July 2010 - 06:55 PM
You can't put the pump on upside down, no.
Posted 30 July 2010 - 08:18 PM
jack
Posted 01 August 2010 - 08:41 AM
Posted 01 August 2010 - 09:37 AM
Filling the oil filter is much more important. The pressure tapping is in the main gallery, oil can't get there until the filter has been filled and it takes a long time to fill that at cranking speed.
