How To Fit A Sump Guard?
17 replies to this topic
#1 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 04 August 2010 - 10:46 AM
I have a sump guard i am wanting to fit but don't know how to fix it to the car, could people show and tell me how they fitted theirs.
#2 lindy119
lindy119
  • 514 posts
  • Local Club: looking for one!!
Posted 04 August 2010 - 12:49 PM
I too would like to know how to do this, so if anyone has any idea please help us!! Free Bump!! :lol:
#3 Stevee
Stevee
  • 0 posts
  • Local Club: #
don't you just bolt it in haha? i want to know aswell :lol:
#4 mk3cortina
mk3cortina
  • 677 posts
Posted 04 August 2010 - 02:03 PM
you offer the sump guard up to the subframe and get it looking right, i.e not touching the sump and square on. then you need to drill the subframe where the sump gueards bolt holes are.
#5 chunkomunko
chunkomunko
  • 350 posts
Posted 04 August 2010 - 03:25 PM
http://www.theminifo...?showtopic=8146
I'll be fitting mine soon so let me know how you get on and any tips you come across!
#6 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 05 August 2010 - 08:14 AM
seems like most people would like to know how to fit a sump guard, i will try take photos when i fit mine
#7 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 05 August 2010 - 10:09 AM
its really not that difficult, only problem i found was getting the bolts into the holes with the nuts on due to space
#8 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 05 August 2010 - 01:07 PM
yeh its just a matter of offering the sump guard up to the subframe, marking where the holes will be and drilling them.
and as daves said its annoying getting the bolts on and off due to the limited space :D
#9 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 05 August 2010 - 03:21 PM
best way would be to put threadded inserts into the holes drilled so you don't need to worry about the nuts the other side of the subframe. something like a rivnut tool would allow you to do this :mmkay:
#10 mike.
mike.
  • 6,176 posts
Posted 05 August 2010 - 04:12 PM
Whoever gets round to doing it first should take aload of pics and write up a how to guide for the FAQ section - As looks like it'd be helpful to alot of people judging by the amount of people asking about them.
#11 mk3cortina
mk3cortina
  • 677 posts
Posted 05 August 2010 - 04:26 PM
what about welding the nut onto the subframe once you have them in place, then you wont have to fiddle about trying to keep a grasp on the nut.
#12 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 05 August 2010 - 10:20 PM
im dropping my subframe out soon and ill buy a sump guard then but i was thinking on lining it all up and then drilling the holes and tapping them to the bolt size
or do captive nuts on the oppiste side? how do people who have rally mini's fit them haha
#13 lindy119
lindy119
  • 514 posts
Posted 11 August 2010 - 10:51 PM
Right....fitted my sump guard today and I have to say it was pretty easy...although I have cheated a bit....
Firstly, apologies for the lack of pics but I completely forgot!!
Anyway, it really is as simple as offering up the sump guard to the subframe and then getting a mate/jack/pile of books to hold it accurately in place while you draw circles through the holes, I used a gold permanent pen but only because it stood out well against the rust!! I'm sure tippex would work too!! Then I pilot drilled through the holes and then fully drilled them.
However, instead of pushing the bolts upwards I have them facing downwards, and although it is still difficult to tighten them it is mugh easier than if it was the other way around. As for how far they stick out, well mine are about perfect and only stick out abit but any longer and they too might start to catch on the ground.
Anyway, after putting the bolts through the subframe and then tightening the nuts I realised it didn't clear the sump properly so I just kept adding washers until I had about 5mm - 6mm clearance, which I think is perfect.
One problem I did have however is that if you face the bolts downwards like I did, when trying to fit the sump guard the washers will just fall off!! So I shaped bluetack into a ring to hold them temporarily while I lined up the sump guard and then it was a piece of piddle!!
If anyone would like me to upload a photo of how it looks now just ask.
Good Luck!! :thumbsup:
#14 CobraV8
CobraV8
  • 991 posts
Posted 12 August 2010 - 09:52 AM
I put the bolts down from above, and put a nut and washer on them. Then... put the sumpguard on and put another nut on. Doing it like this meant I didnt have to get a spanner onto the top of the bolt once the sumpguard was on. Worked well.
#15 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
how are you going to know how much oil your leaking?
