I am considering a slight change of plan, I am now thinking I should try to get my Hayabusa engine started and running myself rather than get Z-cars do it when it goes up for suspension alignment, however before I can get it going I need to source a few ancillary bits .
I have no fuel pump, I have been looking at Merlin Motorsport and Fuel pumps online but with so many available what to buy? obviously I need a filter and again so many to choose from, also do I need a fuel regulator? what about a pressure gauge?
I have not spoken with these or any other suppliers yet, I thought I would ask here for your experiences.
Also I don't have a oil cooler, I may well just join the pipes together as a temporary measure but will obviously need a cooler eventually its been easy to find parts but again which one? Think auto/ Mocal or Merlin Motorsport but again I would like to draw on your experiences on what size and where to get the pipework made up with the Hayabusa flange fitting on the end.
I probably wont bother with cooling or silencer for my initial "fire up" I just want to know if the thing runs
I am afraid I may well be posting a lot of questions like this as it a long time since I have built anything from scratch.
I Want To Start My Hayabusa Engine But Need Some Parts Advice
rustandoil
, Aug 12 2010 02:00 PM
4 replies to this topic
Posted 12 August 2010 - 02:00 PM
Posted 12 August 2010 - 02:44 PM
I dont run an oil cooler but I just do hillclimbs and sprints.
You can blank off the oil cooler pipes but you need to remove a restrictor just behind the oil filter.
Heres what it looks like
Allan
Posted 13 August 2010 - 11:27 AM
Thanks for that Allan
I have spoken with Merlin Motorsport, the chap was very helpful but could not advise on a suitable pump as he needed to know the fuel pressure and flow rate.
Posted 17 August 2010 - 01:00 PM
I cant help with fuel pump I just use the standare Hayabusa pump and regulator.
Allan
Posted 17 August 2010 - 09:24 PM
chris at Zcars does oil cooler take offs that fit to the sump end that then take threaded pipes, they loook good. just use a standard busa pump they do the job great and they have regulator built in as standard,
Try malcolm at yorkshire engines for a pump
http://cgi.ebay.co.u...les_CarParts_SM and one of these coolers are fine, this is similar to the one i used, make sure you use the correct hose and better to get pirtek to crimp the ends on, if one of these pipes burst at high revs, it will fe@k the engine in jig time, spend a bit of money to make sure its done correctly as it could end up an expensive shortcut
Ed
Ed
