this might be a stupid question to alot of u, but will my mini have a main beam and a dipped beam?
i have had to rebuild the front end of my mini and pulled all the wires out and now i have wired them all back up i dont have a main beam, did such a thing exist in 1987? :nugget:
lights
woodsy_1984
, Nov 29 2005 10:10 AM
6 replies to this topic
Posted 29 November 2005 - 10:10 AM
Posted 29 November 2005 - 10:17 AM
yup very much so.
Are you sure it was working before you took it apart?
Posted 29 November 2005 - 10:20 AM
didnt think of checkin before just thought if i connect stuff back to gether it would work, looks like im gonna have to call in a favour from my electrician mate from were i used to work.
ta mate
ta mate
Posted 29 November 2005 - 10:35 AM
Its a possibility that the switch is faulty, or that the sealed beam bulbs are faulty and only working on dip.
On the switch on the l/h side of the column you should have indicators, horn, and main beam.
The main beam switch has 2 settings, either push it forward for constantly on (it clicks to on), and pull it towards you for 'flash'.
Does it work in either setting?
If not then it could be either the switch/bulbs/wiring I'm afraid. There's no real easy way to diagnose....just going to be trial and error :sad:
Posted 29 November 2005 - 10:39 AM
Volt meter (continuity tester) and put it across the terminals, you should have a reading across then, no reading = open circuit = blown lamp..
either that or coonnect it to a 12 v battery with a couple bits of wire.... just to see if it lights up..
Posted 29 November 2005 - 10:40 AM
sure i'll find it thanx mate.just one other thingif u can.how fast do u think 1.3 metro engine is in a mini?
Posted 29 November 2005 - 10:44 AM
Well if its an A series 1.3 metro then it isn't going to be much quicker than a mini 1.3.
