Chris
Posted 18 August 2010 - 09:36 PM
Posted 18 August 2010 - 09:39 PM
I have just been fitting my new cooper S brake kit and I have not got any new back plates for behind the 7.5 inch discs. My dad said make sure you don't need them for your MOT. I was under the impression that I didn't, am I wrong?
Chris
Posted 18 August 2010 - 09:57 PM
Chris
Quite sure you dont. Mine didnt have them and it passed so i assume not but might be different with mot testers?
Posted 19 August 2010 - 07:41 AM
Posted 17 June 2014 - 02:09 PM
Curious if removal of these backplates is legal from an MOT perspective... having problems as one is broken on my MPI...
Posted 17 June 2014 - 02:59 PM
also, do the bolts need to go back into the caliper when they are removed?
Posted 17 June 2014 - 03:04 PM
Edited by cal844, 17 June 2014 - 03:07 PM.
Posted 18 June 2014 - 09:40 PM
Great to know! Did this yesterday in the end, note to others to follow tho: REPLACE THE BOLTS they're the only thing holding the caliper in place!!!
Posted 18 June 2014 - 09:46 PM
I hope this post comes across as me sounding angry. Why did you just advise somebody to not refit the caliper bolts? If you do not know exactly how them back plates are held on please do not comment, ask him to put up pictures or explain exactly what the bolts do before commentingWill pass an mot with them on or off :)
Just leave the bolts out, saves weight
Posted 18 June 2014 - 10:30 PM
Posted 18 June 2014 - 10:40 PM
Chill everyone, no harm done
Re: 'spacer' idea, the metal was perished so didn't bother myself. There were two small washers, which I refitted. Driving experience transformed; no longer sounds like a bag o' bolts!
A
Posted 19 June 2014 - 10:17 AM
Posted 19 June 2014 - 06:38 PM
In my experience the front brake backplates were put on the 7.5 inch Cooper S front discs by BMC/Leyland for a reason.
About 25 years back I was running this set-up without backplates, and I found that in very wet conditions if you needed to brake suddenly there was a very strong tendency for the brakes to 'lag' slightly before they bit and also that under these conditions the braking was often unbalanced. This car was also very light (530kg) and already a handful in the wet, so I could do without the additional brake imbalance problem causing it to lurch to one side or other.
Fitted the backplates and never had this problem again.
Suspect this was all to do with the brake discs getting wet, and this caused the 'lag' before the pads finally cut through the water. This set-up was running standard S discs, not drilled or grooved.
Posted 19 June 2014 - 06:53 PM
