still cant be doing will drilling the subframe tho,
also, i noticed your name is simon,
Posted 20 August 2010 - 07:02 PM
Posted 20 August 2010 - 07:04 PM
hrm, i see,
Posted 20 August 2010 - 07:45 PM
the reason it helps is because the 2 wheels are no longer independent.
when you go round a corner the outside wheel is under stress so therefore the suspension gets compressed, the inside wheel has the weight lifted off of and the body of the car lifts, or 'rolls'
with the roll bar fitted, the outside wheel when under stress twists the bar and transfers some of the force to the other wheel. therefore flattening the car out.
im struggling to explain myself so here
http://auto.howstuff...question432.htm
Posted 21 August 2010 - 12:15 AM
The reason you are struggling to explain is because you haven't read your link correctly and don't know how it works. So try again.
Posted 21 August 2010 - 01:00 AM
and the award for the most stuck up response goes to...
if you cant contribute to the thread then dont post,
if you wanted to correct me and therefore help by adding information in some way then fine, but no, you went for the 'i know better so i am better than you' approach.
shove it up your arse you arrogant pecker
Posted 21 August 2010 - 02:15 AM
the rear one is a little different isnt it! i thought they all mounted right toward the back of the sub frame?
so the front one has 2 mounts on each side, its not connected to the sub frame at all?
and is one of the mounts solid and one bushed?
Posted 21 August 2010 - 07:30 AM
Posted 21 August 2010 - 07:47 AM
