3rd Brake Light?!?
22 replies to this topic
#16 SolarB
SolarB
  • 1,394 posts
Posted 09 November 2010 - 10:12 AM
i made my one at school :unsure: (got an A for it :thumbsup: )
Worked very well till the LED's burnt out :thumbsup:
Didn't they teach you to put a resistor in series with it?
Sorry...................................couldn't resist that.................................I'll go now.
:lol:
#17 lrostoke
lrostoke
  • 6,923 posts
Posted 09 November 2010 - 10:54 AM
On a similar theme we fitted one of the ebay ones to my bro in laws 1970 Auto, I followed him the other day and I noticed that under gentle braking the main brake lights came on dim and the 3rd light not at all. Brand new switch I hasten to add :lol:
The 1970 had the pressure brake switch so we've fitted a relay in the circuit so the pressure switch activates the relay which sends full voltage to the brakes lights.
Works a treat. :unsure: Nice and bright under all braking now
#18 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 09 November 2010 - 11:39 AM
interesting, when peeps have seen my 93' sprite with a 3rd brake light on, they say drivers side brake light doesnt come on if it is its very dim!
This only happens when lights are on at night wonder if i need something to make it brighter?
The 3rd brake light is attached to drivers side light to.
Edited by bunch1980, 09 November 2010 - 11:39 AM.
#19 lrostoke
lrostoke
  • 6,923 posts
Posted 09 November 2010 - 12:02 PM
Could be a bad earth on the drivers side !!
#20 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 09 November 2010 - 12:31 PM
Might very well be as i did quickly attatch it to the screw that holds on boot wire stay!
#21 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 09 November 2010 - 04:19 PM
I got this cheapo one off eBay. simple to fit..works fine.
#22 aavayro
aavayro
  • 89 posts
  • Local Club: D.C.M.O.C
Posted 09 November 2010 - 04:35 PM
i took mine off a car in the scrap yard, a rover 25 i think, fits nice. Dunno if you can see it tho, in top of window
#23 1964Woody
1964Woody
  • 201 posts
Posted 09 November 2010 - 06:38 PM
I got mine from a scrap yard. It was not from a Mini but I looked for a car with the same slope to the back window. I wired it into the brake lights. It works just fine.
If you are still concerned about being seen from behind you should look at brighter lights (LED's) and/or brake flashers. The brake flasher is a small/simple circuit that is wired in between your brake switch and the brake lights. On pressing the brake pedal it gives a number of very quick flashes of the brake lights and then the brake light stays on until you release the pedal. Here is an example of such a circuit: http://www.sentex.ca...c/motflash.html You can adjust the speed of the flashing and the number of flashes. IMHO with brighter lights and the flasher you are more noticeable than with a standard set up and a third brake light. Of course, of of them together would be even better.
NOTE: check your local regulations. Brake light flashers are legal in my Canadian province so long as there are no more than 8 flashes. You need to check that they are legal where you are.
