Overheating And Don't Know Why!
22 replies to this topic
#16 dennisb
dennisb
  • 85 posts
  • Local Club: MiniClan
Posted 27 May 2011 - 09:56 AM
Not tried water pump. Haven't even considered it to be honest... :D
#17 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 27 May 2011 - 08:27 PM
with the balnking sleeve . you have no ristriction in the cooling system .. it does not let the system get real hot . then open the thermostat . and it does not build up as much pressure . i had the same problem in my metro then fitted a sleeve and now no problems
and antifreeze does not make the boiling point rise , just stops it from boiling .... you want water wetter that makes the boiling point higher
#18 dennisb
dennisb
  • 85 posts
Posted 27 May 2011 - 10:58 PM
Nice info NZM, thanks
#19 dennisb
dennisb
  • 85 posts
Posted 30 May 2011 - 06:22 PM
Problem Solved !
Went by my friend Iain's place for a tea and a blether after the Thistle Run run home and mentioned to Stuart there that the car was still overheating.
So I got Mini wiring diagrams, he got his meter and we set about hunting for a cable/connection problem.
He figured out quickly that the relay was fine (being new it should have been) but he realised too that the green/black cable which is a feed out from the ECU was a problem. No signal was getting from the ECU end to the relay to tell it to switch on. The temperature sensor and it's wiring was also proven to be fine.
Next was knowing the suspect cable, so we got the ECU out and opened the loom to look for problems. 3 cables were discovered that had earths running into the ECU which were completely shot. So got them sorted. They had literally turned to dust... but this wasn't the fan problem!
Every wiring diagram showed the green/black cable being a single line from ECU to Relay, yet testing the relay to the ECU showed no flow of current, so of course we were then thinking 'broken cable'...then on ONE of lots of diagrams of the same system, we noticed a wee circular symbol in the line of the cable indicating some sort of connection... turns out that to the left of the fan relay, there is a multiplug that breaks a whole host of cables. 2 pins inside were again totally dust and wrecked, as water had been getting in somehow and corroding away. One of which was this green cable, one was something else, can't remember what. It wasn't clear at all from looking at the route of the cables that this multiplug was part of that system.
Up-shot of it all is that by bridging and bypassing some problem parts the fan's now working a treat, no overheating, have a near-on whole new system I didn't need to get and to top it all off, the car is now going an absolute dream!! Obviously the ECU earthing problems degrading and this multi-plug degrading have slowly been making my engine worse and worse... not any more.
Hopefully this info may help some of you who have a similar problem.
Thanks all for your help!
#20 Liam-MPi
Liam-MPi
  • 58 posts
  • Local Club: Not as yet.
Posted 30 May 2011 - 06:35 PM
Same as others are suggesting. I had the exact same problem, took out the thermostat, dropped it in boiling water and it didn't open. Order a new one along with a couple of gaskets from mini spares will come to no more than £5.
#21 Liam-MPi
Liam-MPi
  • 58 posts
Problem Solved !
My bad, missed your update dude.
#22 stevedx
stevedx
  • 1,312 posts
  • Local Club: brighton mini club
Posted 27 August 2013 - 02:58 PM
mines having issues with the rad fan coming on too, and causing it to overheat.
Mine is just wired permanent now as well for the meantime.
Do you have a pic of this multiplug, thats to the left?
#23 Ipod
Ipod
  • 2,024 posts
Posted 27 August 2013 - 03:07 PM
I'm gonna do it...ready, here we go................. :bah:
