Cam Timing
24 replies to this topic
#16 jamesh1988
jamesh1988
  • 104 posts
Posted 02 September 2010 - 06:16 PM
cheers found it and yea it is 106deg
#17 samsfern
samsfern
  • 5,243 posts
Posted 02 September 2010 - 06:59 PM
i didnt get chance to time mine in today, but i shall be tommorow, ill take some notes for you.
#18 jamesh1988
jamesh1988
  • 104 posts
Posted 02 September 2010 - 09:57 PM
do you think it would be possible to take a couple of photo's also??
#19 samsfern
samsfern
  • 5,243 posts
Posted 03 September 2010 - 07:57 PM
hey, didnt manage to completely time it in, im still 1 degree out, but ive got a pic of it set up with the timing disc, pointer, etc on whilst i was finding the dwell angle, to find true tdc, basically using the dial gauge, i turnt the crank until the piston was at the highest point on the dial gauge, put the timing disc so the pointer pointed to tdc, then kept turning the crank slowly, until the dial gauge started to drop, then looked at where the pointer was on the disc, and marked it. it got to 13 degrees after tdc before the piston started to go back down, this means the dwell angle/period is 13 degrees. so to find true tdc i divided the 13degree dwell by 2, this gave me 6.5 degree, which means to be at true tdc i needed to go back, to 6.5 degree on the timing disc, which i did, then turnt the disc (not the crank) so the pointer was pointing to TDC on the disc, as seen in the pics. i hope you can understand it, as i said, im not very good at explaining things.
i made my pointer out of a bit of ally, then bolted it on using the hole in the front plate that the alternator adjuster bolt goes throug, its a "universal" pointer for two other types of engine i work with at work.
Edited by samsfern, 03 September 2010 - 08:05 PM.
#20 jamesh1988
jamesh1988
  • 104 posts
Posted 03 September 2010 - 09:16 PM
thats spot on just what i was after where did you get your gauge i found the gauges on ebay but cant find them with the magnet bit that sits on the block
#21 samsfern
samsfern
  • 5,243 posts
Posted 03 September 2010 - 09:35 PM
try searching for dial test indicator.
Edited by samsfern, 03 September 2010 - 09:35 PM.
#22 samsfern
samsfern
  • 5,243 posts
Posted 03 September 2010 - 09:50 PM
forgot to mention, theres also a dwell on the cam side of things.
#23 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 03 September 2010 - 11:06 PM
there's a good guide to cam timing on the minispares site written by KC i think, i can't login at the minute so can't link it.
#24 jamesh1988
jamesh1988
  • 104 posts
Posted 04 September 2010 - 07:28 PM
Cheers for the help people done it today borrowed a gauge and all seems well
#25 samsfern
samsfern
  • 5,243 posts
Posted 04 September 2010 - 07:37 PM
i also check again after setting it up, find true tdc again, etc, just incase the disc or pointer has moved.
